[petsc-dev] PetscSFCount is not compatible with MPI_Count
    Fande Kong
    fdkong.jd at gmail.com
    Tue Mar 29 16:49:40 CDT 2022
OK, I attached the configure log here so that we have move information.
I feel like we should do
typedef MPI_Count PetscSFCount
Do we have the target of 64-bit-indices with C++ in CI? I was
surprised that I am the only guy who saw this issue
Fande
On Tue, Mar 29, 2022 at 2:50 PM Satish Balay <balay at mcs.anl.gov> wrote:
> What MPI is this? How to reproduce?
> Perhaps its best if you can send the relevant logs.
> The likely trigger code in sfneighbor.c:
> /* A convenience temporary type */
> #if defined(PETSC_HAVE_MPI_LARGE_COUNT) && defined(PETSC_USE_64BIT_INDICES)
>   typedef PetscInt     PetscSFCount;
> #else
>   typedef PetscMPIInt  PetscSFCount;
> #endif
> This change is at https://gitlab.com/petsc/petsc/-/commit/c87b50c4628
> Hm - if MPI supported LARGE_COUNT - perhaps it also provides a type that
> should go with it which we could use - instead of PetscInt?
> Perhaps it should be: "typedef log PetscSFCount;"
> Satish
> On Tue, 29 Mar 2022, Fande Kong wrote:
> > It seems correct according to
> > #define PETSC_SIZEOF_LONG 8
> > #define PETSC_SIZEOF_LONG_LONG 8
> > Can not convert from "non-constant" to "constant"?
> > Fande
> > On Tue, Mar 29, 2022 at 2:22 PM Fande Kong <fdkong.jd at gmail.com> wrote:
> > > Hi All,
> > > When building PETSc with 64 bit indices, it seems that PetscSFCount is
> > > 64-bit integer while MPI_Count is still 32 bit.
> > > typedef long MPI_Count;
> > >  I had the following errors. Do I have a bad MPI?
> > > Thanks,
> > > Fande
> Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:171:18:
> > > error: no matching function for call to 'MPI_Ineighbor_alltoallv_c'
> PetscCallMPI(MPIU_Ineighbor_alltoallv(rootbuf,dat->rootcounts,dat->rootdispls,unit,leafbuf,dat->leafcounts,dat->leafdispls,unit,distcomm,req));
> /Users/kongf/projects/moose6/petsc1/include/petsc/private/mpiutils.h:97:79:
> > > note: expanded from macro 'MPIU_Ineighbor_alltoallv'
> > >   #define MPIU_Ineighbor_alltoallv(a,b,c,d,e,f,g,h,i,j)
> > >     MPI_Ineighbor_alltoallv_c(a,b,c,d,e,f,g,h,i,j)
> > > /Users/kongf/projects/moose6/petsc1/include/petscerror.h:407:32: note:
> > > expanded from macro 'PetscCallMPI'
> > >     PetscMPIInt _7_errorcode = __VA_ARGS__;
> > > /Users/kongf/mambaforge3/envs/moose/include/mpi_proto.h:945:5: note:
> > > candidate function not viable: no known conversion from 'PetscSFCount
> > > (aka 'long long *') to 'const MPI_Count *' (aka 'const long *') for 2nd
> > > argument
> > > int MPI_Ineighbor_alltoallv_c(const void *sendbuf, const MPI_Count
> > > sendcounts[],
> /Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:195:18:
> PetscCallMPI(MPIU_Ineighbor_alltoallv(leafbuf,dat->leafcounts,dat->leafdispls,unit,rootbuf,dat->rootcounts,dat->rootdispls,unit,distcomm,req));
> > > argument
> > > sendcounts[],
> /Users/kongf/projects/moose6/petsc1/src/vec/is/sf/impls/basic/neighbor/sfneighbor.c:240:18:
> > > error: no matching function for call to 'MPI_Neighbor_alltoallv_c'
> PetscCallMPI(MPIU_Neighbor_alltoallv(rootbuf,dat->rootcounts,dat->rootdispls,unit,leafbuf,dat->leafcounts,dat->leafdispls,unit,comm));
> /Users/kongf/projects/moose6/petsc1/include/petsc/private/mpiutils.h:96:79:
> > > note: expanded from macro 'MPIU_Neighbor_alltoallv'
> > >   #define MPIU_Neighbor_alltoallv(a,b,c,d,e,f,g,h,i)
> > >    MPI_Neighbor_alltoallv_c(a,b,c,d,e,f,g,h,i)
> > > /Users/kongf/mambaforge3/envs/moose/include/mpi_proto.h:1001:5: note:
> > > argument
> > > int MPI_Neighbor_alltoallv_c(const void *sendbuf, const MPI_Count
> > > sendcounts[],
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220329/35d3087f/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220329/35d3087f/attachment-0001.obj>
