[petsc-dev] Gitlab  workflow discussion with GitLab developers
    jacob.fai at gmail.com
    Fri Jan 21 09:32:38 CST 2022
Almost forgot to mention, ask them if they can make popup-boxes (when e.g.
choosing a label, reviewers, etc) size dynamic or at the very least manually
resizable. The size is ok for smaller laptop screens, but only showing at
most 5 items in a 30+ item list on a larger screen with no way to make the
box bigger is a travesty.
Best regards,
Jacob Faibussowitsch
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
| -----Original Message-----
| From: jacob.fai at gmail.com <jacob.fai at gmail.com>
| Sent: Friday, January 21, 2022 07:34
| To: 'Lawrence Mitchell' <wence at gmx.li>; 'Barry Smith' <bsmith at petsc.dev>
| Cc: 'petsc-dev' <petsc-dev at mcs.anl.gov>
| Subject: RE: [petsc-dev] Gitlab workflow discussion with GitLab developers
| 1. Allow searching pipeline jobs by name, type, or tag. I want to be able
to
| find all "linux-cuda-double-64idx" jobs that ran in the last 24 hours, or
all jobs
| that have the tag gpu:nvidia for example. Currently I must manually click
| through the pages and snoop on everyone's pipelines. It would be nice if
the
| https://gitlab.com/petsc/petsc/-/jobs page had the same "filter"
| search box that pipelines have.
| 2. The filter pipelines needs to be able to search for "awaiting
approval".
| I like to cancel all the zombie jobs that MRs create due to
auto-pipelines,
| which so far I have done by manually checking my MRs after pushes.
| Best regards,
| | From: petsc-dev <petsc-dev-bounces at mcs.anl.gov> On Behalf Of
| Lawrence
| | Mitchell
| | Sent: Friday, January 21, 2022 04:32
| | To: Barry Smith <bsmith at petsc.dev>
| | Cc: petsc-dev <petsc-dev at mcs.anl.gov>
| | Subject: Re: [petsc-dev] Gitlab workflow discussion with GitLab
| | developers
| | > On 21 Jan 2022, at 01:05, Barry Smith <bsmith at petsc.dev> wrote:
| | > I got asked to go over some of my Gitlab workflow uses next week
| | > with
| | some Gitlab developers; they do this to understand how Gitlab is used,
| | how it can be improved etc.
| | >  If anyone has ideas on topics I should hit, let me know. I will hit
| them on
| | the brokenness of appropriate code-owners not being automatically
| | added to reviewers. And support for people outside of the Petsc group
| | to set
| more
| | things when they make MRs. And being to easily add non-PETSc folks as
| | reviewers.
| | At least in my experience reviewing large (by diffstat measures) in
| | the browser (I use Safari) is nigh-on unusable since the web interface
| | grinds
| to a
| | halt, and has various other bugs.
| | Of course one should aim for small code changes that are easy to
| | review,
| but
| | often a small code change will produce large changes in the test
| | output
| files
| | (which have to appear in the MR, or else one merges broken code).
| | Some examples, if I go to one of Jacob's recent cleanup MRs:
| | https://gitlab.com/petsc/petsc/-/merge_requests/4700/diffs
| | Dragging the scroll bar is very laggy (I guess there's some background
| thread
| | trying to load things from somewhere?).
| | Semi-randomly, if I click to add a comment on a change, the page jumps
| back
| | to the start and I lose my place.
| | This seems slightly better in Brave (Chromium).
| | I don't know enough about how the web interface/database integration
| | works, but grinding to a halt on a 6000 line diff is unfortunate.
| | Lawrence
