[petsc-dev] Using PETSC with GPUs
    Barry Smith
    bsmith at petsc.dev
    Fri Jan 14 18:05:30 CST 2022
  Just use 1 MPI rank.
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -   - GpuToCpu - GPU
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size   Count   Size  %F
--- Event Stage 0: Main Stage
BuildTwoSided          1 1.0 1.8650e-013467.8 0.00e+00 0.0 2.0e+00 4.0e+00 1.0e+00  0  0  3  0  2   0  0  3  0  4     0       0      0 0.00e+00    0 0.00e+00  0
MatMult               30 1.0 6.6642e+01 1.0 1.16e+10 1.0 6.4e+01 6.4e+08 1.0e+00 65100 91 93  2  65100 91 93  4   346       0      0 0.00e+00   31 2.65e+04  0
From this it is clear the matrix never ended up on the GPU, but the vector did. For each multiply, it is copying the vector from the GPU to the CPU and then doing the MatMult on the CPU. If the MatMult was done on the GPU the file number in the row would be 100% indicating all the flops were done on the GPU and the fifth from the end value of 0 would be some large number, being the flop rate on the GPU.
> On Jan 14, 2022, at 4:59 PM, Rohan Yadav <rohany at alumni.cmu.edu> wrote:
> A log_view is attached at the end of the mail.
> I am running on a large problem size (639 million nonzeros).
> > * I assume you are assembling the matrix on the CPU. The copy of data to the GPU takes time and you really should be creating the matrix on the GPU
> How do I do this? I'm loading the matrix in from a file, but I'm running the computation several times (and with a warmup), so I would expect that the data is copied onto the GPU the first time. My (cpu) code to do this is here: https://github.com/rohany/taco/blob/5c0a4f4419ba392838590ce24e0043f632409e7b/petsc/benchmark.cpp#L68 <https://github.com/rohany/taco/blob/5c0a4f4419ba392838590ce24e0043f632409e7b/petsc/benchmark.cpp#L68>.
> Log view:
> ---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
> ./bin/benchmark on a  named lassen75 with 2 processors, by yadav2 Fri Jan 14 13:54:09 2022
> Using Petsc Release Version 3.16.3, unknown
>                          Max       Max/Min     Avg       Total
> Time (sec):           1.026e+02     1.000   1.026e+02
> Objects:              1.200e+01     1.000   1.200e+01
> Flop:                 1.156e+10     1.009   1.151e+10  2.303e+10
> Flop/sec:             1.127e+08     1.009   1.122e+08  2.245e+08
> MPI Messages:         3.500e+01     1.000   3.500e+01  7.000e+01
> MPI Message Lengths:  2.210e+10     1.000   6.313e+08  4.419e+10
> MPI Reductions:       4.100e+01     1.000
> Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
>                             e.g., VecAXPY() for real vectors of length N --> 2N flop
>                             and VecAXPY() for complex vectors of length N --> 8N flop
> Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages ---  -- Message Lengths --  -- Reductions --
>                         Avg     %Total     Avg     %Total    Count   %Total     Avg         %Total    Count   %Total
>  0:      Main Stage: 1.0257e+02 100.0%  2.3025e+10 100.0%  7.000e+01 100.0%  6.313e+08      100.0%  2.300e+01  56.1%
> See the 'Profiling' chapter of the users' manual for details on interpreting output.
> Phase summary info:
>    Count: number of times phase was executed
>    Time and Flop: Max - maximum over all processors
>                   Ratio - ratio of maximum to minimum over all processors
>    Mess: number of messages sent
>    AvgLen: average message length (bytes)
>    Reduct: number of global reductions
>    Global: entire computation
>    Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
>       %T - percent time in this phase         %F - percent flop in this phase
>       %M - percent messages in this phase     %L - percent message lengths in this phase
>       %R - percent reductions in this phase
>    Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over all processors)
>    GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU time over all processors)
>    CpuToGpu Count: total number of CPU to GPU copies per processor
>    CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per processor)
>    GpuToCpu Count: total number of GPU to CPU copies per processor
>    GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per processor)
>    GPU %F: percent flops on GPU in this event
> MatAssemblyBegin       1 1.0 3.1100e-07 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> MatAssemblyEnd         1 1.0 1.9798e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 4.0e+00 19  0  0  0 10  19  0  0  0 17     0       0      0 0.00e+00    0 0.00e+00  0
> MatLoad                1 1.0 3.5519e+01 1.0 0.00e+00 0.0 6.0e+00 5.4e+08 1.6e+01 35  0  9  7 39  35  0  9  7 70     0       0      0 0.00e+00    0 0.00e+00  0
> VecSet                 5 1.0 5.8959e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> VecScatterBegin       30 1.0 5.4085e+00 1.0 0.00e+00 0.0 6.4e+01 6.4e+08 1.0e+00  5  0 91 93  2   5  0 91 93  4     0       0      0 0.00e+00    0 0.00e+00  0
> VecScatterEnd         30 1.0 9.2544e+00 2.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  6  0  0  0  0   6  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> VecCUDACopyFrom       31 1.0 4.0174e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00   31 2.65e+04  0
> SFSetGraph             1 1.0 4.4912e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> SFSetUp                1 1.0 5.2595e+00 1.0 0.00e+00 0.0 4.0e+00 1.7e+08 1.0e+00  5  0  6  2  2   5  0  6  2  4     0       0      0 0.00e+00    0 0.00e+00  0
> SFPack                30 1.0 3.4021e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> SFUnpack              30 1.0 1.9222e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0 0.00e+00  0
> Memory usage is given in bytes:
> Object Type          Creations   Destructions     Memory  Descendants' Mem.
> Reports information only for process 0.
>               Matrix     3              0            0     0.
>               Viewer     2              0            0     0.
>               Vector     4              1         1792     0.
>            Index Set     2              2    335250404     0.
>    Star Forest Graph     1              0            0     0.
> Average time to get PetscTime(): 3.77e-08
> Average time for MPI_Barrier(): 8.754e-07
> Average time for zero size MPI_Send(): 2.6755e-06
> #PETSc Option Table entries:
> -log_view
> -mat_type aijcusparse
> -matrix /p/gpfs1/yadav2/tensors//petsc/kmer_V1r.petsc
> -n 20
> -vec_type cuda
> -warmup 10
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: --download-c2html=0 --download-hwloc=0 --download-sowing=0 --prefix=./petsc-install/ --with-64-bit-indices=0 --with-blaslapack-lib="/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/liblapack.so /usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/libblas.so" --with-cc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigcc --with-clanguage=C --with-cxx-dialect=C++17 --with-cxx=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpig++ --with-cuda=1 --with-debugging=0 --with-fc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigfortran --with-fftw=0 --with-hdf5-dir=/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4 --with-hdf5=1 --with-mumps=0 --with-precision=double --with-scalapack=0 --with-scalar-type=real --with-shared-libraries=1 --with-ssl=0 --with-suitesparse=0 --with-trilinos=0 --with-valgrind=0 --with-x=0 --with-zlib-include=/usr/include --with-zlib-lib=/usr/lib64/libz.so --with-zlib=1 CFLAGS="-g -DNoChange" COPTFLAGS="-O3" CXXFLAGS="-O3" CXXOPTFLAGS="-O3" FFLAGS=-g CUDAFLAGS=-std=c++17 FOPTFLAGS= PETSC_ARCH=arch-linux-c-opt
> Libraries compiled on 2022-01-14 20:56:04 on lassen99
> Machine characteristics: Linux-4.14.0-115.21.2.1chaos.ch6a.ppc64le-ppc64le-with-redhat-7.6-Maipo
> Using PETSc directory: /g/g15/yadav2/taco/petsc/petsc/petsc-install
> Using PETSc arch:
> Using C compiler: /usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigcc -g -DNoChange -fPIC "-O3"
> Using Fortran compiler: /usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigfortran -g -fPIC
> Using include paths: -I/g/g15/yadav2/taco/petsc/petsc/petsc-install/include -I/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/include -I/usr/include -I/usr/tce/packages/cuda/cuda-11.1.0/include
> Using C linker: /usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigcc
> Using Fortran linker: /usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigfortran
> Using libraries: -Wl,-rpath,/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib -L/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib -lpetsc -Wl,-rpath,/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib -L/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib -Wl,-rpath,/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib -L/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib -Wl,-rpath,/usr/tce/packages/cuda/cuda-11.1.0/lib64 -L/usr/tce/packages/cuda/cuda-11.1.0/lib64 -Wl,-rpath,/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib -L/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8 -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8 -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64 -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64 -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib -llapack -lblas -lhdf5_hl -lhdf5 -lm /usr/lib64/libz.so -lcuda -lcudart -lcufft -lcublas -lcusparse -lcusolver -lcurand -lstdc++ -ldl -lmpiprofilesupport -lmpi_ibm_usempi -lmpi_ibm_mpifh -lmpi_ibm -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lpthread -lquadmath -lstdc++ -ldl
> On Fri, Jan 14, 2022 at 1:43 PM Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
> There are a few things:
> * GPU have higher latencies and so you basically need a large enough problem to get GPU speedup
> * I agree with Barry, Roughly 1M / GPU is around where you start seeing a win but this depends on a lot of things.
> * There are startup costs, like the CPU-GPU copy. It is best to run one mat-vec, or whatever, push a new stage and then run the benchmark. The timing for this new stage will be separate in the log view data. Look at that.
>  - You can fake this by running your benchmark many times to amortize any setup costs.
> On Fri, Jan 14, 2022 at 4:27 PM Rohan Yadav <rohany at alumni.cmu.edu <mailto:rohany at alumni.cmu.edu>> wrote:
> Hi,
> I'm looking to use PETSc with GPUs to do some linear algebra operations, like SpMV, SPMM etc. Building PETSc with `--with-cuda=1` and running with `-mat_type aijcusparse -vec_type cuda` gives me a large slowdown from the same code running on the CPU. This is not entirely unexpected, as things like data transfer costs across the PCIE might erroneously be included in my timing. Are there some examples of benchmarking GPU computations with PETSc, or just the proper way to write code in PETSc that will work for CPUs and GPUs?
> Rohan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220114/e5e2d6ab/attachment-0001.html>
