[petsc-dev] Using PETSC with GPUs
    Rohan Yadav
    rohany at alumni.cmu.edu
    Fri Jan 14 17:28:09 CST 2022
By warm up, I mean run the target computation a few times running the timed
iterations.
Rohan
On Fri, Jan 14, 2022 at 3:18 PM Mark Adams <mfadams at lbl.gov> wrote:
> If you do a warm up you can probably warm it up with another method (like
> MatTransposeMult) to keep your timing separe. It's not clear to me what you
> mean by "warm up" exactly.
> OK, I see you got the GPUs working.
> On Fri, Jan 14, 2022 at 4:59 PM Rohan Yadav <rohany at alumni.cmu.edu> wrote:
>> A log_view is attached at the end of the mail.
>> I am running on a large problem size (639 million nonzeros).
>> > * I assume you are assembling the matrix on the CPU. The copy of data
>> to the GPU takes time and you really should be creating the matrix on the
>> GPU
>> How do I do this? I'm loading the matrix in from a file, but I'm running
>> the computation several times (and with a warmup), so I would expect that
>> the data is copied onto the GPU the first time. My (cpu) code to do this is
>> here:
>> https://github.com/rohany/taco/blob/5c0a4f4419ba392838590ce24e0043f632409e7b/petsc/benchmark.cpp#L68
>> Log view:
>> ---------------------------------------------- PETSc Performance Summary:
>> ./bin/benchmark on a  named lassen75 with 2 processors, by yadav2 Fri Jan
>> 14 13:54:09 2022
>> Using Petsc Release Version 3.16.3, unknown
>>                          Max       Max/Min     Avg       Total
>> Time (sec):           1.026e+02     1.000   1.026e+02
>> Objects:              1.200e+01     1.000   1.200e+01
>> Flop:                 1.156e+10     1.009   1.151e+10  2.303e+10
>> Flop/sec:             1.127e+08     1.009   1.122e+08  2.245e+08
>> MPI Messages:         3.500e+01     1.000   3.500e+01  7.000e+01
>> MPI Message Lengths:  2.210e+10     1.000   6.313e+08  4.419e+10
>> MPI Reductions:       4.100e+01     1.000
>> Flop counting convention: 1 flop = 1 real number operation of type
>> (multiply/divide/add/subtract)
>>                             e.g., VecAXPY() for real vectors of length N
>> --> 2N flop
>>                             and VecAXPY() for complex vectors of length N
>> --> 8N flop
>> Summary of Stages:   ----- Time ------  ----- Flop ------  --- Messages
>> ---  -- Message Lengths --  -- Reductions --
>>                         Avg     %Total     Avg     %Total    Count
>> %Total     Avg         %Total    Count   %Total
>>  0:      Main Stage: 1.0257e+02 100.0%  2.3025e+10 100.0%  7.000e+01
>> 100.0%  6.313e+08      100.0%  2.300e+01  56.1%
>> See the 'Profiling' chapter of the users' manual for details on
>> interpreting output.
>> Phase summary info:
>>    Count: number of times phase was executed
>>    Time and Flop: Max - maximum over all processors
>>                   Ratio - ratio of maximum to minimum over all processors
>>    Mess: number of messages sent
>>    AvgLen: average message length (bytes)
>>    Reduct: number of global reductions
>>    Global: entire computation
>>    Stage: stages of a computation. Set stages with PetscLogStagePush()
>> and PetscLogStagePop().
>>       %T - percent time in this phase         %F - percent flop in this
>> phase
>>       %M - percent messages in this phase     %L - percent message
>> lengths in this phase
>>       %R - percent reductions in this phase
>>    Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time
>>    GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU
>> time over all processors)
>>    CpuToGpu Count: total number of CPU to GPU copies per processor
>>    CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per
>> processor)
>>    GpuToCpu Count: total number of GPU to CPU copies per processor
>>    GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per
>> processor)
>>    GPU %F: percent flops on GPU in this event
>> Event                Count      Time (sec)     Flop
>>        --- Global ---  --- Stage ----  Total   GPU    - CpuToGpu -   -
>> GpuToCpu - GPU
>>                    Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen
>>  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s Mflop/s Count   Size
>> Count   Size  %F
>> --- Event Stage 0: Main Stage
>> BuildTwoSided          1 1.0 1.8650e-013467.8 0.00e+00 0.0 2.0e+00
>> 4.0e+00 1.0e+00  0  0  3  0  2   0  0  3  0  4     0       0      0
>> 0.00e+00    0 0.00e+00  0
>> MatMult               30 1.0 6.6642e+01 1.0 1.16e+10 1.0 6.4e+01 6.4e+08
>> 1.0e+00 65100 91 93  2  65100 91 93  4   346       0      0 0.00e+00   31
>> 2.65e+04  0
>> MatAssemblyBegin       1 1.0 3.1100e-07 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00    0
>> 0.00e+00  0
>> MatAssemblyEnd         1 1.0 1.9798e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 4.0e+00 19  0  0  0 10  19  0  0  0 17     0       0      0 0.00e+00    0
>> 0.00e+00  0
>> MatLoad                1 1.0 3.5519e+01 1.0 0.00e+00 0.0 6.0e+00 5.4e+08
>> 1.6e+01 35  0  9  7 39  35  0  9  7 70     0       0      0 0.00e+00    0
>> 0.00e+00  0
>> VecSet                 5 1.0 5.8959e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.00e+00  0
>> VecScatterBegin       30 1.0 5.4085e+00 1.0 0.00e+00 0.0 6.4e+01 6.4e+08
>> 1.0e+00  5  0 91 93  2   5  0 91 93  4     0       0      0 0.00e+00    0
>> 0.00e+00  0
>> VecScatterEnd         30 1.0 9.2544e+00 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  6  0  0  0  0   6  0  0  0  0     0       0      0 0.00e+00    0
>> 0.00e+00  0
>> VecCUDACopyFrom       31 1.0 4.0174e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.0e+00  0  0  0  0  0   0  0  0  0  0     0       0      0 0.00e+00   31
>> 2.65e+04  0
>> SFSetGraph             1 1.0 4.4912e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.00e+00  0
>> SFSetUp                1 1.0 5.2595e+00 1.0 0.00e+00 0.0 4.0e+00 1.7e+08
>> 1.0e+00  5  0  6  2  2   5  0  6  2  4     0       0      0 0.00e+00    0
>> 0.00e+00  0
>> SFPack                30 1.0 3.4021e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.00e+00  0
>> SFUnpack              30 1.0 1.9222e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
>> 0.00e+00  0
>> Memory usage is given in bytes:
>> Object Type          Creations   Destructions     Memory  Descendants'
>> Mem.
>> Reports information only for process 0.
>>               Matrix     3              0            0     0.
>>               Viewer     2              0            0     0.
>>               Vector     4              1         1792     0.
>>            Index Set     2              2    335250404     0.
>>    Star Forest Graph     1              0            0     0.
>> Average time to get PetscTime(): 3.77e-08
>> Average time for MPI_Barrier(): 8.754e-07
>> Average time for zero size MPI_Send(): 2.6755e-06
>> #PETSc Option Table entries:
>> -log_view
>> -mat_type aijcusparse
>> -matrix /p/gpfs1/yadav2/tensors//petsc/kmer_V1r.petsc
>> -n 20
>> -vec_type cuda
>> -warmup 10
>> #End of PETSc Option Table entries
>> Compiled without FORTRAN kernels
>> Compiled with full precision matrices (default)
>> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
>> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
>> Configure options: --download-c2html=0 --download-hwloc=0
>> --download-sowing=0 --prefix=./petsc-install/ --with-64-bit-indices=0
>> --with-blaslapack-lib="/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/liblapack.so
>> /usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/libblas.so"
>> --with-cc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigcc
>> --with-clanguage=C --with-cxx-dialect=C++17
>> --with-cxx=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpig++
>> --with-cuda=1 --with-debugging=0
>> --with-fc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigfortran
>> --with-fftw=0
>> --with-hdf5-dir=/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4
>> --with-hdf5=1 --with-mumps=0 --with-precision=double --with-scalapack=0
>> --with-scalar-type=real --with-shared-libraries=1 --with-ssl=0
>> --with-suitesparse=0 --with-trilinos=0 --with-valgrind=0 --with-x=0
>> --with-zlib-include=/usr/include --with-zlib-lib=/usr/lib64/libz.so
>> --with-zlib=1 CFLAGS="-g -DNoChange" COPTFLAGS="-O3" CXXFLAGS="-O3"
>> CXXOPTFLAGS="-O3" FFLAGS=-g CUDAFLAGS=-std=c++17 FOPTFLAGS=
>> PETSC_ARCH=arch-linux-c-opt
>> Libraries compiled on 2022-01-14 20:56:04 on lassen99
>> Machine characteristics:
>> Linux-4.14.0-115.21.2.1chaos.ch6a.ppc64le-ppc64le-with-redhat-7.6-Maipo
>> Using PETSc directory: /g/g15/yadav2/taco/petsc/petsc/petsc-install
>> Using PETSc arch:
>> Using C compiler:
>> -g -DNoChange -fPIC "-O3"
>> Using Fortran compiler:
>> -g -fPIC
>> Using include paths:
>> -I/g/g15/yadav2/taco/petsc/petsc/petsc-install/include
>> -I/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/include
>> -I/usr/include -I/usr/tce/packages/cuda/cuda-11.1.0/include
>> Using C linker:
>> Using Fortran linker:
>> Using libraries:
>> -Wl,-rpath,/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib
>> -L/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib -lpetsc
>> -Wl,-rpath,/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib
>> -L/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib
>> -Wl,-rpath,/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib
>> -L/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib
>> -Wl,-rpath,/usr/tce/packages/cuda/cuda-11.1.0/lib64
>> -L/usr/tce/packages/cuda/cuda-11.1.0/lib64
>> -Wl,-rpath,/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib
>> -L/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib
>> -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8
>> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8
>> -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64
>> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64
>> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib -llapack -lblas -lhdf5_hl
>> -lhdf5 -lm /usr/lib64/libz.so -lcuda -lcudart -lcufft -lcublas -lcusparse
>> -lcusolver -lcurand -lstdc++ -ldl -lmpiprofilesupport -lmpi_ibm_usempi
>> -lmpi_ibm_mpifh -lmpi_ibm -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
>> -lpthread -lquadmath -lstdc++ -ldl
>> On Fri, Jan 14, 2022 at 1:43 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> There are a few things:
>>> * GPU have higher latencies and so you basically need a large
>>> enough problem to get GPU speedup
>>> * I assume you are assembling the matrix on the CPU. The copy of data to
>>> the GPU takes time and you really should be creating the matrix on the GPU
>>> * I agree with Barry, Roughly 1M / GPU is around where you start seeing
>>> a win but this depends on a lot of things.
>>> * There are startup costs, like the CPU-GPU copy. It is best to run one
>>> mat-vec, or whatever, push a new stage and then run the benchmark. The
>>> timing for this new stage will be separate in the log view data. Look at
>>> that.
>>>  - You can fake this by running your benchmark many times to amortize
>>> any setup costs.
>>> On Fri, Jan 14, 2022 at 4:27 PM Rohan Yadav <rohany at alumni.cmu.edu>
>>> wrote:
>>>> Hi,
>>>> I'm looking to use PETSc with GPUs to do some linear algebra
>>>> operations, like SpMV, SPMM etc. Building PETSc with `--with-cuda=1` and
>>>> running with `-mat_type aijcusparse -vec_type cuda` gives me a large
>>>> slowdown from the same code running on the CPU. This is not entirely
>>>> unexpected, as things like data transfer costs across the PCIE might
>>>> erroneously be included in my timing. Are there some examples of
>>>> benchmarking GPU computations with PETSc, or just the proper way to write
>>>> code in PETSc that will work for CPUs and GPUs?
>>>> Rohan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220114/d3c1b727/attachment-0001.html>
