[petsc-dev] Using PETSC with GPUs
Rohan Yadav
rohany at alumni.cmu.edu
Fri Jan 14 23:31:39 CST 2022
I was wondering if there is a definitive list for what operations are and
aren't supported for distributed GPU execution. For some operations, like
`MatMult`, it is clear that MPIAIJCUSPARSE implements MatMult from the
documentation, but other operations it is unclear, such as MatMatMult.
Another scenario is the MatAXPY kernel, which supposedly has a
SeqAIJCUSPARSE implementation, which I take means that it can only execute
on a single GPU. However, even if I pass -mat_type seqaijcusparse to the
kernel it doesn't seem to utilize the GPU.
Rohan
On Fri, Jan 14, 2022 at 4:05 PM Barry Smith <bsmith at petsc.dev> wrote:
> Just use 1 MPI rank.
> Event Count Time (sec) Flop
> --- Global --- --- Stage ---- Total GPU - CpuToGpu - -
> GpuToCpu - GPU
> Max Ratio Max Ratio Max Ratio Mess AvgLen
> Reduct %T %F %M %L %R %T %F %M %L %R Mflop/s Mflop/s Count Size
> Count Size %F
> --- Event Stage 0: Main Stage
> BuildTwoSided 1 1.0 1.8650e-013467.8 0.00e+00 0.0 2.0e+00 4.0e+00
> 1.0e+00 0 0 3 0 2 0 0 3 0 4 0 0 0 0.00e+00 0
> 0.00e+00 0
> MatMult 30 1.0 6.6642e+01 1.0 1.16e+10 1.0 6.4e+01 6.4e+08
> 1.0e+00 65100 91 93 2 65100 91 93 4 346 0 0 0.00e+00 31
> 2.65e+04 0
> From this it is clear the matrix never ended up on the GPU, but the vector
> did. For each multiply, it is copying the vector from the GPU to the CPU
> and then doing the MatMult on the CPU. If the MatMult was done on the GPU
> the file number in the row would be 100% indicating all the flops were done
> on the GPU and the fifth from the end value of 0 would be some large
> number, being the flop rate on the GPU.
> On Jan 14, 2022, at 4:59 PM, Rohan Yadav <rohany at alumni.cmu.edu> wrote:
> A log_view is attached at the end of the mail.
> I am running on a large problem size (639 million nonzeros).
> > * I assume you are assembling the matrix on the CPU. The copy of data to
> the GPU takes time and you really should be creating the matrix on the GPU
> How do I do this? I'm loading the matrix in from a file, but I'm running
> the computation several times (and with a warmup), so I would expect that
> the data is copied onto the GPU the first time. My (cpu) code to do this is
> here:
> https://github.com/rohany/taco/blob/5c0a4f4419ba392838590ce24e0043f632409e7b/petsc/benchmark.cpp#L68
> Log view:
> ---------------------------------------------- PETSc Performance Summary:
> ./bin/benchmark on a named lassen75 with 2 processors, by yadav2 Fri Jan
> 14 13:54:09 2022
> Using Petsc Release Version 3.16.3, unknown
> Max Max/Min Avg Total
> Time (sec): 1.026e+02 1.000 1.026e+02
> Objects: 1.200e+01 1.000 1.200e+01
> Flop: 1.156e+10 1.009 1.151e+10 2.303e+10
> Flop/sec: 1.127e+08 1.009 1.122e+08 2.245e+08
> MPI Messages: 3.500e+01 1.000 3.500e+01 7.000e+01
> MPI Message Lengths: 2.210e+10 1.000 6.313e+08 4.419e+10
> MPI Reductions: 4.100e+01 1.000
> Flop counting convention: 1 flop = 1 real number operation of type
> (multiply/divide/add/subtract)
> e.g., VecAXPY() for real vectors of length N
> --> 2N flop
> and VecAXPY() for complex vectors of length N
> --> 8N flop
> Summary of Stages: ----- Time ------ ----- Flop ------ --- Messages
> --- -- Message Lengths -- -- Reductions --
> Avg %Total Avg %Total Count
> %Total Avg %Total Count %Total
> 0: Main Stage: 1.0257e+02 100.0% 2.3025e+10 100.0% 7.000e+01
> 100.0% 6.313e+08 100.0% 2.300e+01 56.1%
> See the 'Profiling' chapter of the users' manual for details on
> interpreting output.
> Phase summary info:
> Count: number of times phase was executed
> Time and Flop: Max - maximum over all processors
> Ratio - ratio of maximum to minimum over all processors
> Mess: number of messages sent
> AvgLen: average message length (bytes)
> Reduct: number of global reductions
> Global: entire computation
> Stage: stages of a computation. Set stages with PetscLogStagePush() and
> PetscLogStagePop().
> %T - percent time in this phase %F - percent flop in this
> phase
> %M - percent messages in this phase %L - percent message lengths
> in this phase
> %R - percent reductions in this phase
> Total Mflop/s: 10e-6 * (sum of flop over all processors)/(max time over
> all processors)
> GPU Mflop/s: 10e-6 * (sum of flop on GPU over all processors)/(max GPU
> time over all processors)
> CpuToGpu Count: total number of CPU to GPU copies per processor
> CpuToGpu Size (Mbytes): 10e-6 * (total size of CPU to GPU copies per
> processor)
> GpuToCpu Count: total number of GPU to CPU copies per processor
> GpuToCpu Size (Mbytes): 10e-6 * (total size of GPU to CPU copies per
> processor)
> GPU %F: percent flops on GPU in this event
> GpuToCpu - GPU
> Count Size %F
> 0.00e+00 0
> 2.65e+04 0
> MatAssemblyBegin 1 1.0 3.1100e-07 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0 0.00e+00 0
> 0.00e+00 0
> MatAssemblyEnd 1 1.0 1.9798e+01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 4.0e+00 19 0 0 0 10 19 0 0 0 17 0 0 0 0.00e+00 0
> 0.00e+00 0
> MatLoad 1 1.0 3.5519e+01 1.0 0.00e+00 0.0 6.0e+00 5.4e+08
> 1.6e+01 35 0 9 7 39 35 0 9 7 70 0 0 0 0.00e+00 0
> 0.00e+00 0
> VecSet 5 1.0 5.8959e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> VecScatterBegin 30 1.0 5.4085e+00 1.0 0.00e+00 0.0 6.4e+01 6.4e+08
> 1.0e+00 5 0 91 93 2 5 0 91 93 4 0 0 0 0.00e+00 0
> 0.00e+00 0
> VecScatterEnd 30 1.0 9.2544e+00 2.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 6 0 0 0 0 6 0 0 0 0 0 0 0 0.00e+00 0
> 0.00e+00 0
> VecCUDACopyFrom 31 1.0 4.0174e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0 0 0 0.00e+00 31
> 2.65e+04 0
> SFSetGraph 1 1.0 4.4912e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> SFSetUp 1 1.0 5.2595e+00 1.0 0.00e+00 0.0 4.0e+00 1.7e+08
> 1.0e+00 5 0 6 2 2 5 0 6 2 4 0 0 0 0.00e+00 0
> 0.00e+00 0
> SFPack 30 1.0 3.4021e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> SFUnpack 30 1.0 1.9222e-05 1.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.00e+00 0
> Memory usage is given in bytes:
> Object Type Creations Destructions Memory Descendants' Mem.
> Reports information only for process 0.
> Matrix 3 0 0 0.
> Viewer 2 0 0 0.
> Vector 4 1 1792 0.
> Index Set 2 2 335250404 0.
> Star Forest Graph 1 0 0 0.
> Average time to get PetscTime(): 3.77e-08
> Average time for MPI_Barrier(): 8.754e-07
> Average time for zero size MPI_Send(): 2.6755e-06
> #PETSc Option Table entries:
> -log_view
> -mat_type aijcusparse
> -matrix /p/gpfs1/yadav2/tensors//petsc/kmer_V1r.petsc
> -n 20
> -vec_type cuda
> -warmup 10
> #End of PETSc Option Table entries
> Compiled without FORTRAN kernels
> Compiled with full precision matrices (default)
> sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8
> sizeof(PetscScalar) 8 sizeof(PetscInt) 4
> Configure options: --download-c2html=0 --download-hwloc=0
> --download-sowing=0 --prefix=./petsc-install/ --with-64-bit-indices=0
> --with-blaslapack-lib="/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/liblapack.so
> /usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib/libblas.so"
> --with-cc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigcc
> --with-clanguage=C --with-cxx-dialect=C++17
> --with-cxx=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpig++
> --with-cuda=1 --with-debugging=0
> --with-fc=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-gcc-8.3.1/bin/mpigfortran
> --with-fftw=0
> --with-hdf5-dir=/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4
> --with-hdf5=1 --with-mumps=0 --with-precision=double --with-scalapack=0
> --with-scalar-type=real --with-shared-libraries=1 --with-ssl=0
> --with-suitesparse=0 --with-trilinos=0 --with-valgrind=0 --with-x=0
> --with-zlib-include=/usr/include --with-zlib-lib=/usr/lib64/libz.so
> --with-zlib=1 CFLAGS="-g -DNoChange" COPTFLAGS="-O3" CXXFLAGS="-O3"
> CXXOPTFLAGS="-O3" FFLAGS=-g CUDAFLAGS=-std=c++17 FOPTFLAGS=
> PETSC_ARCH=arch-linux-c-opt
> Libraries compiled on 2022-01-14 20:56:04 on lassen99
> Machine characteristics:
> Linux-4.14.0-115.21.2.1chaos.ch6a.ppc64le-ppc64le-with-redhat-7.6-Maipo
> Using PETSc directory: /g/g15/yadav2/taco/petsc/petsc/petsc-install
> Using PETSc arch:
> Using C compiler:
> -g -DNoChange -fPIC "-O3"
> Using Fortran compiler:
> -g -fPIC
> Using include paths:
> -I/g/g15/yadav2/taco/petsc/petsc/petsc-install/include
> -I/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/include
> -I/usr/include -I/usr/tce/packages/cuda/cuda-11.1.0/include
> Using C linker:
> Using Fortran linker:
> Using libraries:
> -Wl,-rpath,/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib
> -L/g/g15/yadav2/taco/petsc/petsc/petsc-install/lib -lpetsc
> -Wl,-rpath,/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib
> -L/usr/tcetmp/packages/lapack/lapack-3.9.0-gcc-7.3.1/lib
> -Wl,-rpath,/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib
> -L/usr/tcetmp/packages/petsc/build/3.13.0/spack/opt/spack/linux-rhel7-power9le/xl_r-16.1/hdf5-1.10.6-e7e7urb5k7va3ib7j4uro56grvzmcmd4/lib
> -Wl,-rpath,/usr/tce/packages/cuda/cuda-11.1.0/lib64
> -L/usr/tce/packages/cuda/cuda-11.1.0/lib64
> -Wl,-rpath,/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib
> -L/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/lib
> -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8
> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib/gcc/ppc64le-redhat-linux/8
> -Wl,-rpath,/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64
> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib64
> -L/usr/tce/packages/gcc/gcc-8.3.1/rh/usr/lib -llapack -lblas -lhdf5_hl
> -lhdf5 -lm /usr/lib64/libz.so -lcuda -lcudart -lcufft -lcublas -lcusparse
> -lcusolver -lcurand -lstdc++ -ldl -lmpiprofilesupport -lmpi_ibm_usempi
> -lmpi_ibm_mpifh -lmpi_ibm -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath
> -lpthread -lquadmath -lstdc++ -ldl
> On Fri, Jan 14, 2022 at 1:43 PM Mark Adams <mfadams at lbl.gov> wrote:
>> There are a few things:
>> * GPU have higher latencies and so you basically need a large
>> enough problem to get GPU speedup
>> * I agree with Barry, Roughly 1M / GPU is around where you start seeing a
>> win but this depends on a lot of things.
>> * There are startup costs, like the CPU-GPU copy. It is best to run one
>> mat-vec, or whatever, push a new stage and then run the benchmark. The
>> timing for this new stage will be separate in the log view data. Look at
>> that.
>> - You can fake this by running your benchmark many times to amortize any
>> setup costs.
>> On Fri, Jan 14, 2022 at 4:27 PM Rohan Yadav <rohany at alumni.cmu.edu>
>> wrote:
>>> Hi,
>>> I'm looking to use PETSc with GPUs to do some linear algebra operations,
>>> like SpMV, SPMM etc. Building PETSc with `--with-cuda=1` and running with
>>> `-mat_type aijcusparse -vec_type cuda` gives me a large slowdown from the
>>> same code running on the CPU. This is not entirely unexpected, as things
>>> like data transfer costs across the PCIE might erroneously be included in
>>> my timing. Are there some examples of benchmarking GPU computations with
>>> PETSc, or just the proper way to write code in PETSc that will work for
>>> CPUs and GPUs?
>>> Rohan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20220114/07f323b7/attachment-0001.html>
