[petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
    Stefano Zampini
    stefano.zampini at gmail.com
    Mon Sep 13 23:44:19 CDT 2021
I'll see if I can reproduce
Il Mar 14 Set 2021, 06:58 Junchao Zhang <junchao.zhang at gmail.com> ha
scritto:
> Hi, Stefano,
>    Ping you again to see if you want to resolve this problem before
> petsc-3.16
> --Junchao Zhang
> On Sun, Sep 12, 2021 at 3:06 PM Antonio T. sagitter <
> sagitter at fedoraproject.org> wrote:
>> Unfortunately, it's not possible. I must use the OpenMPI provided by
>> Fedora build-system (these rpm builds of PETSc are for Fedora's
>> repositories), downloading external software is not permitted.
>> On 9/12/21 21:10, Pierre Jolivet wrote:
>> >> On 12 Sep 2021, at 8:56 PM, Matthew Knepley <knepley at gmail.com
>> >> <mailto:knepley at gmail.com>> wrote:
>> >> On Sun, Sep 12, 2021 at 2:49 PM Antonio T. sagitter
>> >> <sagitter at fedoraproject.org <mailto:sagitter at fedoraproject.org>>
>> wrote:
>> >>     Those attached are configure.log/make.log from a MPI build in
>> >>     Fedora 34
>> >>     x86_64 where the error below occurred.
>> >> This is OpenMPI 4.1.0. Is that the only MPI you build? My first
>> >> inclination is that this is an MPI implementation bug.
>> >> Junchao, do we have an OpenMPI build in the CI?
>> > config/examples/arch-ci-linux-cuda-double-64idx.py:
>> >   '--download-openmpi=1',
>> > config/examples/arch-ci-linux-pkgs-dbg-ftn-interfaces.py:
>> > config/examples/arch-ci-linux-pkgs-opt.py:  '--download-openmpi=1',
>> > config/BuildSystem/config/packages/OpenMPI.py uses version 4.1.0 as
>> well.
>> > I’m not sure PETSc is to blame here Antonio. You may want to try to
>> > ditch the OpenMPI shipped by your packet manager and try
>> > --download-openmpi as well, just for a quick sanity check.
>> > Thanks,
>> > Pierre
>> Antonio Trande
>> Fedora Project
>> mailto: sagitter at fedoraproject.org
>> GPG key: 0x29FBC85D7A51CC2F
>> GPG key server: https://keyserver1.pgp.com/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210914/4b934fd6/attachment-0001.html>
