[petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
Junchao Zhang
junchao.zhang at gmail.com
Mon Sep 13 22:57:55 CDT 2021
Hi, Stefano,
Ping you again to see if you want to resolve this problem before
petsc-3.16
--Junchao Zhang
On Sun, Sep 12, 2021 at 3:06 PM Antonio T. sagitter <
sagitter at fedoraproject.org> wrote:
> Unfortunately, it's not possible. I must use the OpenMPI provided by
> Fedora build-system (these rpm builds of PETSc are for Fedora's
> repositories), downloading external software is not permitted.
> On 9/12/21 21:10, Pierre Jolivet wrote:
> >> On 12 Sep 2021, at 8:56 PM, Matthew Knepley <knepley at gmail.com
> >> <mailto:knepley at gmail.com>> wrote:
> >> On Sun, Sep 12, 2021 at 2:49 PM Antonio T. sagitter
> >> <sagitter at fedoraproject.org <mailto:sagitter at fedoraproject.org>> wrote:
> >> Those attached are configure.log/make.log from a MPI build in
> >> Fedora 34
> >> x86_64 where the error below occurred.
> >> This is OpenMPI 4.1.0. Is that the only MPI you build? My first
> >> inclination is that this is an MPI implementation bug.
> >> Junchao, do we have an OpenMPI build in the CI?
> > config/examples/arch-ci-linux-cuda-double-64idx.py:
> > '--download-openmpi=1',
> > config/examples/arch-ci-linux-pkgs-dbg-ftn-interfaces.py:
> > config/examples/arch-ci-linux-pkgs-opt.py: '--download-openmpi=1',
> > config/BuildSystem/config/packages/OpenMPI.py uses version 4.1.0 as well.
> > I’m not sure PETSc is to blame here Antonio. You may want to try to
> > ditch the OpenMPI shipped by your packet manager and try
> > --download-openmpi as well, just for a quick sanity check.
> > Thanks,
> > Pierre
> Antonio Trande
> Fedora Project
> mailto: sagitter at fedoraproject.org
> GPG key: 0x29FBC85D7A51CC2F
> GPG key server: https://keyserver1.pgp.com/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210913/9d7e9453/attachment.html>
