[petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
Antonio T. sagitter sagitter at fedoraproject.org
Sun Sep 12 15:06:05 CDT 2021
Unfortunately, it's not possible. I must use the OpenMPI provided by
Fedora build-system (these rpm builds of PETSc are for Fedora's
repositories), downloading external software is not permitted.
On 9/12/21 21:10, Pierre Jolivet wrote:
>> On 12 Sep 2021, at 8:56 PM, Matthew Knepley <knepley at gmail.com
>> <mailto:knepley at gmail.com>> wrote:
>> On Sun, Sep 12, 2021 at 2:49 PM Antonio T. sagitter
>> <sagitter at fedoraproject.org <mailto:sagitter at fedoraproject.org>> wrote:
>>     Those attached are configure.log/make.log from a MPI build in
>>     Fedora 34
>>     x86_64 where the error below occurred.
>> This is OpenMPI 4.1.0. Is that the only MPI you build? My first
>> inclination is that this is an MPI implementation bug.
>> Junchao, do we have an OpenMPI build in the CI?
> config/examples/arch-ci-linux-cuda-double-64idx.py:
>   '--download-openmpi=1',
> config/examples/arch-ci-linux-pkgs-dbg-ftn-interfaces.py:
> config/examples/arch-ci-linux-pkgs-opt.py:  '--download-openmpi=1',
> config/BuildSystem/config/packages/OpenMPI.py uses version 4.1.0 as well.
> I’m not sure PETSc is to blame here Antonio. You may want to try to
> ditch the OpenMPI shipped by your packet manager and try
> --download-openmpi as well, just for a quick sanity check.
> Thanks,
> Pierre
Antonio Trande
Fedora Project
mailto: sagitter at fedoraproject.org
GPG key: 0x29FBC85D7A51CC2F
GPG key server: https://keyserver1.pgp.com/
