[petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
Satish Balay
balay at mcs.anl.gov
Sun Sep 12 11:15:46 CDT 2021
> you either need to copy the files from the datafiles repository
Actually clone https://gitlab.com/petsc/datafiles and use its location with DATAFILESPATH option
But yeah - its not really needed. If DATAFILESPATH is missing - the corresponding tests won't be run.
Satish
On Sun, 12 Sep 2021, Pierre Jolivet wrote:
> Hello,
> Did you copy the files from https://gitlab.com/petsc/datafiles <https://gitlab.com/petsc/datafiles> before the make check?
> cfd.1.10 is not part of https://gitlab.com/petsc/petsc <https://gitlab.com/petsc/petsc>, so you either need to copy the files from the datafiles repository, or remove the --DATAFILESPATH=/home/sagitter/rpmbuild/BUILD/petsc-3.15.4/petsc-3.15.4/share/petsc/datafiles configure option.
> Thanks,
> Pierre
> > On 12 Sep 2021, at 6:02 PM, Antonio T. sagitter <sagitter at fedoraproject.org> wrote:
> > Hi all.
> > This error is repeated when the tests are compiled in PETSc-3.15.4 compilation:
> > https://paste.in/MhdNjf
> > This happens in Fedora 34 x86_64 with gcc-11.2.1
> > make.log and configure.log are attached
> > Antonio Trande
> > Fedora Project
> > mailto: sagitter at fedoraproject.org
> > GPG key: 0x29FBC85D7A51CC2F
> > GPG key server: https://keyserver1.pgp.com/
> > <make_configure.zip><OpenPGP_0x29FBC85D7A51CC2F.asc>
