[petsc-dev] Cannot locate file: share/petsc/datafiles/matrices/small
    Pierre Jolivet
    pierre at joliv.et
    Sun Sep 12 11:09:08 CDT 2021
Hello,
Did you copy the files from https://gitlab.com/petsc/datafiles <https://gitlab.com/petsc/datafiles> before the make check?
cfd.1.10 is not part of https://gitlab.com/petsc/petsc <https://gitlab.com/petsc/petsc>, so you either need to copy the files from the datafiles repository, or remove the --DATAFILESPATH=/home/sagitter/rpmbuild/BUILD/petsc-3.15.4/petsc-3.15.4/share/petsc/datafiles configure option.
Pierre
> On 12 Sep 2021, at 6:02 PM, Antonio T. sagitter <sagitter at fedoraproject.org> wrote:
> Hi all.
> This error is repeated when the tests are compiled in PETSc-3.15.4 compilation:
> https://paste.in/MhdNjf
> This happens in Fedora 34 x86_64 with gcc-11.2.1
> make.log and configure.log are attached
> Antonio Trande
> Fedora Project
> mailto: sagitter at fedoraproject.org
> GPG key: 0x29FBC85D7A51CC2F
> GPG key server: https://keyserver1.pgp.com/
> <make_configure.zip><OpenPGP_0x29FBC85D7A51CC2F.asc>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210912/93a62c78/attachment.html>
