[petsc-dev] testset
Mark Adams
mfadams at lbl.gov
Sat Nov 20 08:13:44 CST 2021
I am trying to add a test set and I am getting this error with the appended
syntax.
I do not see the problem. Any ideas?
06:03 2 nid003756 main *= perlmutter:~/petsc$ *make
PETSC_DIR=/global/homes/m/madams/petsc PETSC_ARCH=arch-perlmutter-opt-gcc
-f gmakefile test search='ts_utils_dmplexlandau_tutorials-ex2_0'*
/usr/bin/python /global/homes/m/madams/petsc/config/gmakegentest.py
--petsc-dir=/global/homes/m/madams/petsc
--petsc-arch=arch-perlmutter-opt-gcc
--testdir=./arch-perlmutter-opt-gcc/tests
Traceback (most recent call last):
File "/global/homes/m/madams/petsc/config/gmakegentest.py", line 1093, in
<module>
testdir=opts.testdir, check=opts.check_output)
File "/global/homes/m/madams/petsc/config/gmakegentest.py", line 1060, in
main
dataDict=pEx.walktree(os.path.join(pEx.srcdir))
File "/global/homes/m/madams/petsc/config/gmakegentest.py", line 924, in
walktree
self.genPetscTests(root,dirs,files,dataDict)
File "/global/homes/m/madams/petsc/config/gmakegentest.py", line 897, in
genPetscTests
dataDict[root].update(testparse.parseTestFile(fullex,0))
File "/global/homes/m/madams/petsc/config/testparse.py", line 542, in
parseTestFile
testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity)
File "/global/homes/m/madams/petsc/config/testparse.py", line 498, in
parseTests
testnames,subdicts=parseTest(test,srcfile,verbosity)
File "/global/homes/m/madams/petsc/config/testparse.py", line 426, in
parseTest
if not var in acceptedkeys: raise Exception("Keyword: "+var+" from:
"+line+" is not valid")
Exception: Keyword: est from: est: is not valid
make: *** [gmakefile.test:97: arch-perlmutter-opt-gcc/tests/testfiles]
Error 1
06:08 2 nid003756 main *= perlmutter:~/petsc$
/*TEST
testset:
requires: p4est !complex double
output_file: output/ex2_0.out
args: -dm_landau_num_species_grid 1,1 -dm_landau_Ez 0 -petscspace_degree
3 -petscspace_poly_tensor 1 -dm_landau_type p4est -info :dm,tsadapt
-dm_landau_ion_masses 2 -dm_landau_ion_charges 1 -dm_landau_thermal_temps
5,5 -dm_landau_n 2,2 -dm_landau_n_0 5e19 -ts_monitor -snes_rtol 1.e-10
-snes_stol 1.e-14 -snes_monitor -snes_converged_reason -snes_max_it 10
-ts_type arkimex -ts_arkimex_type 1bee -ts_max_snes_failures -1 -ts_rtol
1e-3 -ts_dt 1.e-1 -ts_max_time 1 -ts_adapt_clip .5,1.25 -ts_max_steps 2
-ts_adapt_scale_solve_failed 0.75 -ts_adapt_time_step_increase_delay 5
-pc_type lu -ksp_type preonly -dm_landau_amr_levels_max 2,2
-ex2_impurity_source_type pulse -ex2_pulse_start_time 1e-1
-ex2_pulse_width_time 10 -ex2_pulse_rate 1e-2 -ex2_t_cold .05 -ex2_plot_dt
1e-1 -dm_refine 1 -dm_landau_gpu_assembly true -dm_landau_batch_size 2
test:
suffix: 0
requires: !kokkos_kernels !cuda
args: -dm_landau_device_type cpu
test:
suffix: kokkos
requires: kokkos_kernels
args: -dm_landau_device_type kokkos -dm_mat_type aijkokkos -dm_vec_type
kokkos
test:
suffix: cuda
requires: cuda
args: -dm_landau_device_type cuda -dm_mat_type aijcusparse -dm_vec_type
cuda -mat_cusparse_use_cpu_solve
TEST*/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211120/1d3b6a4b/attachment.html>
