[petsc-dev] testset
Sat Nov 20 10:52:16 CST 2021
On Sat, Nov 20, 2021 at 9:14 AM Mark Adams <mfadams at lbl.gov> wrote:
> I am trying to add a test set and I am getting this error with the
> appended syntax.
> I do not see the problem. Any ideas?
Maybe not enough indenting for "test:" ? It is clear that one of those
lines is the problem.
    Matt
> Thanks,
> Mark
> 06:03 2 nid003756 main *= perlmutter:~/petsc$ *make
> PETSC_DIR=/global/homes/m/madams/petsc PETSC_ARCH=arch-perlmutter-opt-gcc
> -f gmakefile test search='ts_utils_dmplexlandau_tutorials-ex2_0'*
> /usr/bin/python /global/homes/m/madams/petsc/config/gmakegentest.py
> --petsc-dir=/global/homes/m/madams/petsc
> --petsc-arch=arch-perlmutter-opt-gcc
> --testdir=./arch-perlmutter-opt-gcc/tests
> Traceback (most recent call last):
>   File "/global/homes/m/madams/petsc/config/gmakegentest.py", line 1093,
> in <module>
>     testdir=opts.testdir, check=opts.check_output)
>   File "/global/homes/m/madams/petsc/config/gmakegentest.py", line 1060,
> in main
>     dataDict=pEx.walktree(os.path.join(pEx.srcdir))
>   File "/global/homes/m/madams/petsc/config/gmakegentest.py", line 924, in
> walktree
>     self.genPetscTests(root,dirs,files,dataDict)
>   File "/global/homes/m/madams/petsc/config/gmakegentest.py", line 897, in
> genPetscTests
>     dataDict[root].update(testparse.parseTestFile(fullex,0))
>   File "/global/homes/m/madams/petsc/config/testparse.py", line 542, in
> parseTestFile
>     testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity)
>   File "/global/homes/m/madams/petsc/config/testparse.py", line 498, in
> parseTests
>     testnames,subdicts=parseTest(test,srcfile,verbosity)
>   File "/global/homes/m/madams/petsc/config/testparse.py", line 426, in
> parseTest
>     if not var in acceptedkeys: raise Exception("Keyword: "+var+" from:
> "+line+" is not valid")
> Exception: Keyword: est from: est: is not valid
> make: *** [gmakefile.test:97: arch-perlmutter-opt-gcc/tests/testfiles]
> Error 1
> 06:08 2 nid003756 main *= perlmutter:~/petsc$
> /*TEST
>  testset:
>    requires: p4est !complex double
>    output_file: output/ex2_0.out
>    args: -dm_landau_num_species_grid 1,1 -dm_landau_Ez 0
> -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type p4est -info
> :dm,tsadapt -dm_landau_ion_masses 2 -dm_landau_ion_charges 1
> -dm_landau_thermal_temps 5,5 -dm_landau_n 2,2 -dm_landau_n_0 5e19
> -ts_monitor -snes_rtol 1.e-10 -snes_stol 1.e-14 -snes_monitor
> -snes_converged_reason -snes_max_it 10 -ts_type arkimex -ts_arkimex_type
> 1bee -ts_max_snes_failures -1 -ts_rtol 1e-3 -ts_dt 1.e-1 -ts_max_time 1
> -ts_adapt_clip .5,1.25 -ts_max_steps 2 -ts_adapt_scale_solve_failed 0.75
> -ts_adapt_time_step_increase_delay 5 -pc_type lu -ksp_type preonly
> -dm_landau_amr_levels_max 2,2 -ex2_impurity_source_type pulse
> -ex2_pulse_start_time 1e-1 -ex2_pulse_width_time 10 -ex2_pulse_rate 1e-2
> -ex2_t_cold .05 -ex2_plot_dt 1e-1 -dm_refine 1 -dm_landau_gpu_assembly true
> -dm_landau_batch_size 2
>   test:
>     suffix: 0
>     requires:  !kokkos_kernels !cuda
>     args: -dm_landau_device_type cpu
>   test:
>     suffix: kokkos
>     requires: kokkos_kernels
>     args: -dm_landau_device_type kokkos -dm_mat_type aijkokkos
> -dm_vec_type kokkos
>   test:
>     suffix: cuda
>     requires: cuda
>     args: -dm_landau_device_type cuda -dm_mat_type aijcusparse
> -dm_vec_type cuda -mat_cusparse_use_cpu_solve
> TEST*/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211120/4abaa296/attachment.html>
