[petsc-dev] CUDA + OpenMP on Summit with Hypre
Mark Adams mfadams at lbl.gov
Mon Nov 15 10:38:11 CST 2021
Yea, Stefano mentioned this and I would also like to see this not be a
fatal error.
On Mon, Nov 15, 2021 at 9:26 AM Jacob Faibussowitsch <jacob.fai at gmail.com>
wrote:
> > [0]PETSC ERROR: PETSc is configured with GPU support, but your MPI is
>> not GPU-aware. For better performance, please use a GPU-aware MPI.
>> > [0]PETSC ERROR: If you do not care, add option -use_gpu_aware_mpi 0. To
>> not see the message again, add the option to your .petscrc, OR add it to
>> the env var PETSC_OPTIONS.
>> > [0]PETSC ERROR: If you do care, for IBM Spectrum MPI on OLCF Summit,
>> you may need jsrun --smpiargs=-gpu.
>> > [0]PETSC ERROR: For OpenMPI, you need to configure it --with-cuda (
>> https://www.open-mpi.org/faq/?category=buildcuda)
>> > [0]PETSC ERROR: For MVAPICH2-GDR, you need to set MV2_USE_CUDA=1 (
>> http://mvapich.cse.ohio-state.edu/userguide/gdr/)
>> > [0]PETSC ERROR: For Cray-MPICH, you need to set
>> MPICH_RDMA_ENABLED_CUDA=1 (
>> https://www.olcf.ornl.gov/tutorials/gpudirect-mpich-enabled-cuda/)
> You seem to also be tripping up the gpu aware mpi checker. IIRC we
> discussed removing this at some point? I think Stefano mentioned we now do
> this check at configure time?
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> On Nov 13, 2021, at 22:57, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> On Sat, Nov 13, 2021 at 2:24 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I have a user that wants CUDA + Hypre on Sumit and they want to use
>> OpenMP in their code. I configured with openmp but without thread safety
>> and got this error.
>> Maybe there is no need for us to do anything with omp in our
>> configuration. Not sure.
>> 15:08 main= summit:/gpfs/alpine/csc314/scratch/adams/petsc$ make
>> PETSC_DIR=/gpfs/alpine/world-shared/geo127/petsc/arch-opt-gcc9.1.0-omp-cuda11.0.3
>> PETSC_ARCH="" check
>> Running check examples to verify correct installation
>> Using
>> and PETSC_ARCH=
>> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
>> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
>> See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> [1] (280696) Warning: Could not find key lid0:0:2 in cache
>> [1] (280696) Warning: Could not find key qpn0:0:0:2 in cache
>> Unable to connect queue-pairs
>> [h37n08:280696] Error: common_pami.c:1094 - ompi_common_pami_init() 1:
>> Unable to create 1 PAMI communication context(s) rc=1
> I don't know what petsc's thread safety is.  But this error seems to be in
> the environment.   You can report to OLCF help.
>> No components were able to be opened in the pml framework.
>> This typically means that either no components of this type were
>> installed, or none of the installed components can be loaded.
>> Sometimes this means that shared libraries required by these
>> components are unable to be found/loaded.
>>   Host:      h37n08
>>   Framework: pml
>> [h37n08:280696] PML pami cannot be selected
>> 1,5c1,16
>> < lid velocity = 0.0016, prandtl # = 1., grashof # = 1.
>> <   0 SNES Function norm 0.0406612
>> <   1 SNES Function norm 4.12227e-06
>> <   2 SNES Function norm 6.098e-11
>> < Number of SNES iterations = 2
>> > [1] (280721) Warning: Could not find key lid0:0:2 in cache
>> > [1] (280721) Warning: Could not find key qpn0:0:0:2 in cache
>> > [h37n08:280721] Error: common_pami.c:1094 - ompi_common_pami_init() 1:
>> >   Host:      h37n08
>> >   Framework: pml
>> > [h37n08:280721] PML pami cannot be selected
>> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials
>> Possible problem with ex19 running with hypre, diffs above
>> 2,15c2,15
>> <   0 SNES Function norm 2.391552133017e-01
>> <     0 KSP Residual norm 2.325621076120e-01
>> <     1 KSP Residual norm 1.654206318674e-02
>> <     2 KSP Residual norm 7.202836119880e-04
>> <     3 KSP Residual norm 1.796861424199e-05
>> <     4 KSP Residual norm 2.461332992052e-07
>> <   1 SNES Function norm 6.826585648929e-05
>> <     0 KSP Residual norm 2.347339172985e-05
>> <     1 KSP Residual norm 8.356798075993e-07
>> <     2 KSP Residual norm 1.844045309619e-08
>> <     3 KSP Residual norm 5.336386977405e-10
>> <     4 KSP Residual norm 2.662608472862e-11
>> <   2 SNES Function norm 6.549682264799e-11
>> > MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_SELF
>> > with errorcode 76.
>> > NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
>> > You may or may not see output from other processes, depending on
>> > exactly when Open MPI kills them.
>> Possible problem with ex19 running with cuda, diffs above
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20211115/6c21856f/attachment-0001.html>
