[petsc-dev] Listing failed tests
    Scott Kruger
    kruger at txcorp.com
    Mon May 17 12:23:31 CDT 2021
On 2021-05-17 16:20, Stefano Zampini did write:
> This was changed recently, I still don’t know why.
Developer 1:  This test output is too verbose.
Developer 2:  This test output is too terse.
I'll shoot for a Goldilocks MR.
Scott
> I also find very convenient to have the list of failing tests printed at the end, instead of having to manually scroll up the output.
> For now, you can edit gmakefile.test and fix showreport variable
>  showreport = "-s"
> Which is now set only if you are running the entire testsuite, and not a selected set of tests.]
> > On May 17, 2021, at 4:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > I have looked at the test system documentation, but I cannot figure out how to make it list the failed tests at the end of a run. It used to do this by default.
> >   Thanks,
> >     Matt
> > What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Scott Kruger
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
Boulder, CO 80303                Fax:   (303) 448-7756
