[petsc-dev] Listing failed tests
Stefano Zampini
stefano.zampini at gmail.com
Mon May 17 08:20:01 CDT 2021
This was changed recently, I still don’t know why.
I also find very convenient to have the list of failing tests printed at the end, instead of having to manually scroll up the output.
For now, you can edit gmakefile.test and fix showreport variable
showreport = "-s"
Which is now set only if you are running the entire testsuite, and not a selected set of tests.]
> On May 17, 2021, at 4:16 PM, Matthew Knepley <knepley at gmail.com> wrote:
> I have looked at the test system documentation, but I cannot figure out how to make it list the failed tests at the end of a run. It used to do this by default.
> Thanks,
> Matt
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210517/500910fd/attachment.html>
