[petsc-dev] Listing failed tests
Matthew Knepley
knepley at gmail.com
Mon May 17 12:45:45 CDT 2021
On Mon, May 17, 2021 at 1:23 PM Scott Kruger <kruger at txcorp.com> wrote:
> On 2021-05-17 16:20, Stefano Zampini did write:
> > This was changed recently, I still don’t know why.
> Developer 1: This test output is too verbose.
> Developer 2: This test output is too terse.
> I'll shoot for a Goldilocks MR.
Hi Scott,
I don't need you to change it. I would like to be able to turn it on
myself. I think we should just add another option
that sets showreport. I can do it if you want.
Matt
> Scott
> > I also find very convenient to have the list of failing tests printed at
> the end, instead of having to manually scroll up the output.
> > For now, you can edit gmakefile.test and fix showreport variable
> > showreport = "-s"
> > Which is now set only if you are running the entire testsuite, and not a
> selected set of tests.]
> > > On May 17, 2021, at 4:16 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > I have looked at the test system documentation, but I cannot figure
> out how to make it list the failed tests at the end of a run. It used to do
> this by default.
> > > Thanks,
> > > Matt
> > > What most experimenters take for granted before they begin their
> experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
> Scott Kruger
> Tech-X Corporation kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
> Boulder, CO 80303 Fax: (303) 448-7756
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210517/8df44e8b/attachment.html>
