[petsc-dev] Problem with the reorganization of complex with clang
Junchao Zhang
junchao.zhang at gmail.com
Fri May 14 10:28:05 CDT 2021
Satish, how to access this machine? I want to know why complex is screwed
up.
--Junchao Zhang
On Thu, May 13, 2021 at 7:08 PM Matthew Knepley <knepley at gmail.com> wrote:
> Nope. I will use your fix.
> Thanks,
> Matt
> On Thu, May 13, 2021 at 7:55 PM Matthew Knepley <knepley at gmail.com> wrote:
>> I am going to try just including petscsys.h and see if it works.
>> Thanks,
>> Matt
>> On Thu, May 13, 2021 at 6:23 PM Satish Balay <balay at mcs.anl.gov> wrote:
>>> This gets the build going...
>>> diff --git a/src/sys/dll/cxx/demangle.cxx b/src/sys/dll/cxx/demangle.cxx
>>> index 31810ea15f..793a97d285 100644
>>> --- a/src/sys/dll/cxx/demangle.cxx
>>> +++ b/src/sys/dll/cxx/demangle.cxx
>>> @@ -1,3 +1,4 @@
>>> +#define PETSC_SKIP_COMPLEX
>>> #include <petsc/private/petscimpl.h>
>>> #ifdef PETSC_HAVE_CXXABI_H
>>> Satish
>>> On Thu, 13 May 2021, Satish Balay wrote:
>>> > > CXX arch-ci-linux-clang-avx/obj/sys/dll/cxx/demangle.o
>>> > It is built with a c++ compiler - so __cplusplus should be defined.
>>> [PETSC_HAVE_CXXABI is not defined]
>>> > Do you need to build this sourcefile file in a clanguage=C build?
>>> > I'm not sure if a c++/complex build is checked with this compiler.
>>> > [eventhough its clang build - I see the compiler is using system
>>> incldues aka from gcc-4.8.5 - so perhaps some things don't work?]
>>> > One option is to add the following to this sourcefile:
>>> > Satish
>>> > On Thu, 13 May 2021, Matthew Knepley wrote:
>>> > > In this CI run (linux-clang-avg):
>>> > > https://gitlab.com/petsc/petsc/-/jobs/1260342204
>>> > > The compile fails building a C++ file, demangle.cxx. It fails at the
>>> first
>>> > > line,
>>> > > including <petsc/private/petscimpl.h>, down in petscsystypes.h. It
>>> bombs
>>> > > during the definition of complex because it looks like the compiler
>>> is not
>>> > > defining __cplusplus, and thus takes the wrong branch. Is this what
>>> is
>>> > > happening?
>>> > > I cannot access this machine.
>>> > > Thanks,
>>> > > Matt
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210514/ab474825/attachment.html>
