[petsc-dev] Problem with the reorganization of complex with clang
    Satish Balay
    balay at mcs.anl.gov
    Fri May 14 10:42:06 CDT 2021
You can login to: isdp001.cels.anl.gov - using your MCS account credentials [and then setup ~/.ssh/authorized_keys]
Satish
On Fri, 14 May 2021, Junchao Zhang wrote:
> Satish, how to access this machine? I want to know why complex is screwed
> up.
> --Junchao Zhang
> On Thu, May 13, 2021 at 7:08 PM Matthew Knepley <knepley at gmail.com> wrote:
> > Nope. I will use your fix.
> >   Thanks,
> >      Matt
> > On Thu, May 13, 2021 at 7:55 PM Matthew Knepley <knepley at gmail.com> wrote:
> >> I am going to try just including petscsys.h and see if it works.
> >>   Thanks,
> >>      Matt
> >> On Thu, May 13, 2021 at 6:23 PM Satish Balay <balay at mcs.anl.gov> wrote:
> >>> This gets the build going...
> >>> diff --git a/src/sys/dll/cxx/demangle.cxx b/src/sys/dll/cxx/demangle.cxx
> >>> index 31810ea15f..793a97d285 100644
> >>> --- a/src/sys/dll/cxx/demangle.cxx
> >>> +++ b/src/sys/dll/cxx/demangle.cxx
> >>> @@ -1,3 +1,4 @@
> >>> +#define PETSC_SKIP_COMPLEX
> >>>  #include <petsc/private/petscimpl.h>
> >>>  #ifdef PETSC_HAVE_CXXABI_H
> >>> Satish
> >>> On Thu, 13 May 2021, Satish Balay wrote:
> >>> > >         CXX arch-ci-linux-clang-avx/obj/sys/dll/cxx/demangle.o
> >>> > It is built with a c++ compiler - so __cplusplus should be defined.
> >>> [PETSC_HAVE_CXXABI is not defined]
> >>> > Do you need to build this sourcefile file in a clanguage=C build?
> >>> > I'm not sure if a c++/complex build  is checked with this compiler.
> >>> > [eventhough its clang build - I see the compiler is using system
> >>> incldues aka from gcc-4.8.5 - so perhaps some things don't work?]
> >>> > One option is to add the following to this sourcefile:
> >>> > Satish
> >>> > On Thu, 13 May 2021, Matthew Knepley wrote:
> >>> > > In this CI run (linux-clang-avg):
> >>> > >   https://gitlab.com/petsc/petsc/-/jobs/1260342204
> >>> > > The compile fails building a C++ file, demangle.cxx. It fails at the
> >>> first
> >>> > > line,
> >>> > > including <petsc/private/petscimpl.h>, down in petscsystypes.h. It
> >>> bombs
> >>> > > during the definition of complex because it looks like the compiler
> >>> is not
> >>> > > defining __cplusplus, and thus takes the wrong branch. Is this what
> >>> is
> >>> > > happening?
> >>> > > I cannot access this machine.
> >>> > >   Thanks,
> >>> > >       Matt
> >> What most experimenters take for granted before they begin their
> >> experiments is infinitely more interesting than any results to which their
> >> experiments lead.
> >> -- Norbert Wiener
> >> https://www.cse.buffalo.edu/~knepley/
> >> <http://www.cse.buffalo.edu/~knepley/>
> > experiments lead.
> > -- Norbert Wiener
