[petsc-dev] Problem with the reorganization of complex with clang
Matthew Knepley
knepley at gmail.com
Thu May 13 19:08:10 CDT 2021
Nope. I will use your fix.
Matt
On Thu, May 13, 2021 at 7:55 PM Matthew Knepley <knepley at gmail.com> wrote:
> I am going to try just including petscsys.h and see if it works.
> Thanks,
> Matt
> On Thu, May 13, 2021 at 6:23 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> This gets the build going...
>> diff --git a/src/sys/dll/cxx/demangle.cxx b/src/sys/dll/cxx/demangle.cxx
>> index 31810ea15f..793a97d285 100644
>> --- a/src/sys/dll/cxx/demangle.cxx
>> +++ b/src/sys/dll/cxx/demangle.cxx
>> @@ -1,3 +1,4 @@
>> +#define PETSC_SKIP_COMPLEX
>> #include <petsc/private/petscimpl.h>
>> #ifdef PETSC_HAVE_CXXABI_H
>> Satish
>> On Thu, 13 May 2021, Satish Balay wrote:
>> > > CXX arch-ci-linux-clang-avx/obj/sys/dll/cxx/demangle.o
>> > It is built with a c++ compiler - so __cplusplus should be defined.
>> [PETSC_HAVE_CXXABI is not defined]
>> > Do you need to build this sourcefile file in a clanguage=C build?
>> > I'm not sure if a c++/complex build is checked with this compiler.
>> > [eventhough its clang build - I see the compiler is using system
>> incldues aka from gcc-4.8.5 - so perhaps some things don't work?]
>> > One option is to add the following to this sourcefile:
>> > Satish
>> > On Thu, 13 May 2021, Matthew Knepley wrote:
>> > > In this CI run (linux-clang-avg):
>> > > https://gitlab.com/petsc/petsc/-/jobs/1260342204
>> > > The compile fails building a C++ file, demangle.cxx. It fails at the
>> first
>> > > line,
>> > > including <petsc/private/petscimpl.h>, down in petscsystypes.h. It
>> bombs
>> > > during the definition of complex because it looks like the compiler
>> is not
>> > > defining __cplusplus, and thus takes the wrong branch. Is this what is
>> > > happening?
>> > > I cannot access this machine.
>> > > Thanks,
>> > > Matt
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210513/6e60a2af/attachment.html>
