[petsc-dev] reproducing crashes in the test harness
Matthew Knepley
knepley at gmail.com
Tue Mar 30 05:37:00 CDT 2021
On Tue, Mar 30, 2021 at 12:25 AM Barry Smith <bsmith at petsc.dev> wrote:
> # FAILED snes_tutorials-ex12_quad_hpddm_reuse_threshold
> snes_tutorials-ex12_p4est_nc_singular_2d_hpddm snes_tutorials-ex56_hpddm
> snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij sys_tests-ex53_2
> snes_tutorials-ex12_quad_hpddm_reuse_baij
> snes_tutorials-ex12_p4est_singular_2d_hpddm
> snes_tutorials-ex12_tri_parmetis_hpddm
> snes_tutorials-ex12_quad_singular_hpddm sys_tests-ex26_1 sys_tests-ex26_2
> snes_tutorials-ex12_tri_parmetis_hpddm_baij
> snes_tutorials-ex12_tri_hpddm_reuse_baij snes_tutorials-ex12_tri_hpddm_reus
> Scott,
> Any thoughts on how the test harness could tell the developer exactly
> how to reproduce a problematic cases in the debugger without them digging
> around in the code to check arguments etc.
> So for example "Run: mpiexec -n N ./xxx args -start_in_debugger" to
> reproduce this problem? Then one could just cut and paste and be debugging
> away.
I always just EXTRA_ARGUMENTS="-start_in_debugger". However, if you really
want to run standalone, V=1 will display the args I think
Matt
> Thanks
> Barry
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210330/cc81c7e4/attachment.html>
