[petsc-dev] reproducing crashes in the test harness
Barry Smith bsmith at petsc.dev
Mon Mar 29 23:25:02 CDT 2021
# FAILED snes_tutorials-ex12_quad_hpddm_reuse_threshold snes_tutorials-ex12_p4est_nc_singular_2d_hpddm snes_tutorials-ex56_hpddm snes_tutorials-ex12_quad_hpddm_reuse_threshold_baij sys_tests-ex53_2 snes_tutorials-ex12_quad_hpddm_reuse_baij snes_tutorials-ex12_quad_hpddm_reuse snes_tutorials-ex12_p4est_singular_2d_hpddm snes_tutorials-ex12_tri_parmetis_hpddm snes_tutorials-ex12_quad_singular_hpddm sys_tests-ex26_1 sys_tests-ex26_2 snes_tutorials-ex12_tri_parmetis_hpddm_baij snes_tutorials-ex12_tri_hpddm_reuse_baij snes_tutorials-ex12_tri_hpddm_reus
Scott,
  Any thoughts on how the test harness could tell the developer exactly how to reproduce a problematic cases in the debugger without them digging around in the code to check arguments etc.
  So for example "Run: mpiexec -n N ./xxx args -start_in_debugger" to reproduce this problem? Then one could just cut and paste and be debugging away.
  Thanks
  Barry
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210329/94490b6a/attachment-0001.html>
