[petsc-dev] Are pipelines down?
Fri Mar 12 09:56:52 CST 2021
And I see you started one pipeline:
https://gitlab.com/danfinn/petsc/-/jobs/1091965415
its started on 'danfinn/petsc' repo - that doesn't have petsc CI permissions.
You should 'run pipeline' from https://gitlab.com/petsc/petsc/-/merge_requests/3707//pipelines
And the pipeline started by Pierre shows (formatting) errors that need fixing.
https://gitlab.com/petsc/petsc/-/jobs/1093419052
Satish
On Fri, 12 Mar 2021, Satish Balay via petsc-dev wrote:
> Only folk in developer group have permissions to use the CI resources
> [to avoid drive by hacks and consumption of resources etc]
> And as a developer you have to create a 'new pipeline' - not use the
> auto-started pipeline [this auto-stated pipeline from a fork is from a
> user account that does not have access to CI resources - so these
> pipelines will stay stuck]
> I think its best for one of the developers to start the pipeline after
> verifying the code is ok to run.  If any of the reviewers approve -
> then I can do this.
> Satish
> On Fri, 12 Mar 2021, Matthew Knepley wrote:
> > On Fri, Mar 12, 2021 at 9:26 AM Pierre Jolivet <pierre at joliv.et> wrote:
> > > You are linking to the forks, i.e., not …/petsc/petsc/…, you’ll never see
> > > anything going on there, I think.
> > > I’ve started the pipelines by clicking “Run Pipeline” here
> > > https://gitlab.com/petsc/petsc/-/merge_requests/3616/pipelines and there
> > > https://gitlab.com/petsc/petsc/-/merge_requests/3707/pipelines
> > Thanks Pierre. There are things I obviously do not understand about Gitlab
> >    Matt
> > > Thanks,
> > > Pierre
> > > On 12 Mar 2021, at 3:02 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > > On Fri, Mar 12, 2021 at 7:29 AM Matthew Knepley <knepley at gmail.com> wrote:
> > >> On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > >>> For forks - a member of the developer group needs to start a new
> > >>> pipeline. (after basic checks on the changes)
> > >> The original pipeline just sat pending in the source check, so I
> > >> cancelled it.
> > >> I created a new pipeline, but it is just sitting pending in the source
> > >> check
> > >>   https://gitlab.com/danfinn/petsc/-/pipelines/269297070
> > >> Why will this not run?
> > > Same problem for Connor's branch:
> > > https://gitlab.com/connorjward/petsc/-/pipelines/269584870
> > >    Matt
> > >>   Thanks,
> > >>      Matt
> > >>> Satish
> > >>> On Thu, 11 Mar 2021, Jed Brown wrote:
> > >>> > Says the pipeline was canceled. The branch comes from a fork so it
> > >>> should need approval to run.
> > >>> > Matthew Knepley <knepley at gmail.com> writes:
> > >>> > >   Thanks,
> > >>> > >      Matt
> > >>> > > What most experimenters take for granted before they begin their
> > >>> > > experiments is infinitely more interesting than any results to which
> > >>> their
> > >>> > > experiments lead.
> > >>> > > -- Norbert Wiener
> > >>> > > https://www.cse.buffalo.edu/~knepley/ <
> > >>> http://www.cse.buffalo.edu/~knepley/>
> > >> experiments is infinitely more interesting than any results to which their
> > >> experiments lead.
> > >> -- Norbert Wiener
> > >> <http://www.cse.buffalo.edu/~knepley/>
> > > experiments lead.
> > > -- Norbert Wiener
