[petsc-dev] Are pipelines down?
Satish Balay
balay at mcs.anl.gov
Fri Mar 12 09:44:56 CST 2021
Only folk in developer group have permissions to use the CI resources
[to avoid drive by hacks and consumption of resources etc]
And as a developer you have to create a 'new pipeline' - not use the
auto-started pipeline [this auto-stated pipeline from a fork is from a
user account that does not have access to CI resources - so these
pipelines will stay stuck]
I think its best for one of the developers to start the pipeline after
verifying the code is ok to run. If any of the reviewers approve -
then I can do this.
Satish
On Fri, 12 Mar 2021, Matthew Knepley wrote:
> On Fri, Mar 12, 2021 at 9:26 AM Pierre Jolivet <pierre at joliv.et> wrote:
> > You are linking to the forks, i.e., not …/petsc/petsc/…, you’ll never see
> > anything going on there, I think.
> > I’ve started the pipelines by clicking “Run Pipeline” here
> > https://gitlab.com/petsc/petsc/-/merge_requests/3616/pipelines and there
> > https://gitlab.com/petsc/petsc/-/merge_requests/3707/pipelines
> Thanks Pierre. There are things I obviously do not understand about Gitlab
> Matt
> > Thanks,
> > Pierre
> > On 12 Mar 2021, at 3:02 PM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Fri, Mar 12, 2021 at 7:29 AM Matthew Knepley <knepley at gmail.com> wrote:
> >> On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <balay at mcs.anl.gov> wrote:
> >>> For forks - a member of the developer group needs to start a new
> >>> pipeline. (after basic checks on the changes)
> >> The original pipeline just sat pending in the source check, so I
> >> cancelled it.
> >> I created a new pipeline, but it is just sitting pending in the source
> >> check
> >> https://gitlab.com/danfinn/petsc/-/pipelines/269297070
> >> Why will this not run?
> > Same problem for Connor's branch:
> > https://gitlab.com/connorjward/petsc/-/pipelines/269584870
> > Matt
> >> Thanks,
> >> Matt
> >>> Satish
> >>> On Thu, 11 Mar 2021, Jed Brown wrote:
> >>> > Says the pipeline was canceled. The branch comes from a fork so it
> >>> should need approval to run.
> >>> > Matthew Knepley <knepley at gmail.com> writes:
> >>> > > Thanks,
> >>> > > Matt
> >>> > > What most experimenters take for granted before they begin their
> >>> > > experiments is infinitely more interesting than any results to which
> >>> their
> >>> > > experiments lead.
> >>> > > -- Norbert Wiener
> >>> > > https://www.cse.buffalo.edu/~knepley/ <
> >>> http://www.cse.buffalo.edu/~knepley/>
> >> experiments is infinitely more interesting than any results to which their
> >> experiments lead.
> >> -- Norbert Wiener
> >> <http://www.cse.buffalo.edu/~knepley/>
> > experiments lead.
> > -- Norbert Wiener
