[petsc-dev] Are pipelines down?
Matthew Knepley
knepley at gmail.com
Fri Mar 12 10:00:48 CST 2021
On Fri, Mar 12, 2021 at 10:57 AM Satish Balay <balay at mcs.anl.gov> wrote:
> And I see you started one pipeline:
> https://gitlab.com/danfinn/petsc/-/jobs/1091965415
> its started on 'danfinn/petsc' repo - that doesn't have petsc CI
> permissions.
> You should 'run pipeline' from
> https://gitlab.com/petsc/petsc/-/merge_requests/3707//pipelines
> And the pipeline started by Pierre shows (formatting) errors that need
> fixing.
> https://gitlab.com/petsc/petsc/-/jobs/1093419052
Yes, I am fixing those.
Matt
> Satish
> On Fri, 12 Mar 2021, Satish Balay via petsc-dev wrote:
> > Only folk in developer group have permissions to use the CI resources
> > [to avoid drive by hacks and consumption of resources etc]
> > And as a developer you have to create a 'new pipeline' - not use the
> > auto-started pipeline [this auto-stated pipeline from a fork is from a
> > user account that does not have access to CI resources - so these
> > pipelines will stay stuck]
> > I think its best for one of the developers to start the pipeline after
> > verifying the code is ok to run. If any of the reviewers approve -
> > then I can do this.
> > Satish
> > On Fri, 12 Mar 2021, Matthew Knepley wrote:
> > > On Fri, Mar 12, 2021 at 9:26 AM Pierre Jolivet <pierre at joliv.et>
> wrote:
> > > > You are linking to the forks, i.e., not …/petsc/petsc/…, you’ll
> never see
> > > > anything going on there, I think.
> > > > I’ve started the pipelines by clicking “Run Pipeline” here
> > > > https://gitlab.com/petsc/petsc/-/merge_requests/3616/pipelines and
> there
> > > > https://gitlab.com/petsc/petsc/-/merge_requests/3707/pipelines
> > > Thanks Pierre. There are things I obviously do not understand about
> Gitlab
> > > Matt
> > > > Thanks,
> > > > Pierre
> > > > On 12 Mar 2021, at 3:02 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > > > On Fri, Mar 12, 2021 at 7:29 AM Matthew Knepley <knepley at gmail.com>
> wrote:
> > > >> On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > >>> For forks - a member of the developer group needs to start a new
> > > >>> pipeline. (after basic checks on the changes)
> > > >> The original pipeline just sat pending in the source check, so I
> > > >> cancelled it.
> > > >> I created a new pipeline, but it is just sitting pending in the
> source
> > > >> check
> > > >> https://gitlab.com/danfinn/petsc/-/pipelines/269297070
> > > >> Why will this not run?
> > > > Same problem for Connor's branch:
> > > > https://gitlab.com/connorjward/petsc/-/pipelines/269584870
> > > > Matt
> > > >> Thanks,
> > > >> Matt
> > > >>> Satish
> > > >>> On Thu, 11 Mar 2021, Jed Brown wrote:
> > > >>> > Says the pipeline was canceled. The branch comes from a fork so
> it
> > > >>> should need approval to run.
> > > >>> > Matthew Knepley <knepley at gmail.com> writes:
> > > >>> > > Thanks,
> > > >>> > > Matt
> > > >>> > > What most experimenters take for granted before they begin
> their
> > > >>> > > experiments is infinitely more interesting than any results to
> which
> > > >>> their
> > > >>> > > experiments lead.
> > > >>> > > -- Norbert Wiener
> > > >>> > > https://www.cse.buffalo.edu/~knepley/ <
> > > >>> http://www.cse.buffalo.edu/~knepley/>
> > > >> What most experimenters take for granted before they begin their
> which their
> > > >> experiments lead.
> > > >> -- Norbert Wiener
> > > >> <http://www.cse.buffalo.edu/~knepley/>
> > > > experiments is infinitely more interesting than any results to which
> their
> > > > experiments lead.
> > > > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210312/51ba24f1/attachment-0001.html>
