[petsc-dev] Are pipelines down?
Matthew Knepley
knepley at gmail.com
Fri Mar 12 09:11:14 CST 2021
On Fri, Mar 12, 2021 at 9:26 AM Pierre Jolivet <pierre at joliv.et> wrote:
> You are linking to the forks, i.e., not …/petsc/petsc/…, you’ll never see
> anything going on there, I think.
> I’ve started the pipelines by clicking “Run Pipeline” here
> https://gitlab.com/petsc/petsc/-/merge_requests/3616/pipelines and there
> https://gitlab.com/petsc/petsc/-/merge_requests/3707/pipelines
Thanks Pierre. There are things I obviously do not understand about Gitlab
Matt
> Thanks,
> Pierre
> On 12 Mar 2021, at 3:02 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Mar 12, 2021 at 7:29 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <balay at mcs.anl.gov> wrote:
>>> For forks - a member of the developer group needs to start a new
>>> pipeline. (after basic checks on the changes)
>> The original pipeline just sat pending in the source check, so I
>> cancelled it.
>> I created a new pipeline, but it is just sitting pending in the source
>> check
>> https://gitlab.com/danfinn/petsc/-/pipelines/269297070
>> Why will this not run?
> Same problem for Connor's branch:
> https://gitlab.com/connorjward/petsc/-/pipelines/269584870
> Matt
>> Thanks,
>> Matt
>>> Satish
>>> On Thu, 11 Mar 2021, Jed Brown wrote:
>>> > Says the pipeline was canceled. The branch comes from a fork so it
>>> should need approval to run.
>>> > Matthew Knepley <knepley at gmail.com> writes:
>>> > > Thanks,
>>> > > Matt
>>> > > What most experimenters take for granted before they begin their
>>> > > experiments is infinitely more interesting than any results to which
>>> their
>>> > > experiments lead.
>>> > > -- Norbert Wiener
>>> > > https://www.cse.buffalo.edu/~knepley/ <
>>> http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210312/00043954/attachment-0001.html>
