[petsc-dev] Are pipelines down?
    Pierre Jolivet
    pierre at joliv.et
    Fri Mar 12 08:26:36 CST 2021
You are linking to the forks, i.e., not …/petsc/petsc/…, you’ll never see anything going on there, I think.
I’ve started the pipelines by clicking “Run Pipeline” here https://gitlab.com/petsc/petsc/-/merge_requests/3616/pipelines <https://gitlab.com/petsc/petsc/-/merge_requests/3616/pipelines> and there https://gitlab.com/petsc/petsc/-/merge_requests/3707/pipelines <https://gitlab.com/petsc/petsc/-/merge_requests/3707/pipelines>
Pierre
> On 12 Mar 2021, at 3:02 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Mar 12, 2021 at 7:29 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
> On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <balay at mcs.anl.gov <mailto:balay at mcs.anl.gov>> wrote:
> For forks - a member of the developer group needs to start a new pipeline. (after basic checks on the changes)
> The original pipeline just sat pending in the source check, so I cancelled it.
> I created a new pipeline, but it is just sitting pending in the source check
>   https://gitlab.com/danfinn/petsc/-/pipelines/269297070 <https://gitlab.com/danfinn/petsc/-/pipelines/269297070>
> Why will this not run?
> Same problem for Connor's branch: https://gitlab.com/connorjward/petsc/-/pipelines/269584870 <https://gitlab.com/connorjward/petsc/-/pipelines/269584870>
>    Matt
>   Thanks,
>      Matt
> Satish
> On Thu, 11 Mar 2021, Jed Brown wrote:
> > Says the pipeline was canceled. The branch comes from a fork so it should need approval to run.
> > https://gitlab.com/petsc/petsc/-/merge_requests/3707 <https://gitlab.com/petsc/petsc/-/merge_requests/3707>
> > Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> writes:
> > >   Thanks,
> > >      Matt
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to which their
> > > experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/ <https://www.cse.buffalo.edu/~knepley/> <http://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>>
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210312/2ed3cd6b/attachment.html>
