[petsc-dev] Are pipelines down?
Fri Mar 12 08:02:13 CST 2021
On Fri, Mar 12, 2021 at 7:29 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <balay at mcs.anl.gov> wrote:
>> For forks - a member of the developer group needs to start a new
>> pipeline. (after basic checks on the changes)
> The original pipeline just sat pending in the source check, so I cancelled
> it.
> I created a new pipeline, but it is just sitting pending in the source
> check
>   https://gitlab.com/danfinn/petsc/-/pipelines/269297070
> Why will this not run?
Same problem for Connor's branch:
https://gitlab.com/connorjward/petsc/-/pipelines/269584870
   Matt
>   Thanks,
>      Matt
>> Satish
>> On Thu, 11 Mar 2021, Jed Brown wrote:
>> > Says the pipeline was canceled. The branch comes from a fork so it
>> should need approval to run.
>> > https://gitlab.com/petsc/petsc/-/merge_requests/3707
>> > Matthew Knepley <knepley at gmail.com> writes:
>> > >   Thanks,
>> > >      Matt
>> > > What most experimenters take for granted before they begin their
>> > > experiments is infinitely more interesting than any results to which
>> their
>> > > experiments lead.
>> > > -- Norbert Wiener
>> > > https://www.cse.buffalo.edu/~knepley/ <
>> http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210312/20803c3e/attachment.html>
