[petsc-dev] Are pipelines down?
Matthew Knepley
knepley at gmail.com
Fri Mar 12 06:29:31 CST 2021
On Thu, Mar 11, 2021 at 11:24 PM Satish Balay <balay at mcs.anl.gov> wrote:
> For forks - a member of the developer group needs to start a new pipeline.
> (after basic checks on the changes)
The original pipeline just sat pending in the source check, so I cancelled
it.
I created a new pipeline, but it is just sitting pending in the source check
https://gitlab.com/danfinn/petsc/-/pipelines/269297070
Why will this not run?
Matt
> Satish
> On Thu, 11 Mar 2021, Jed Brown wrote:
> > Says the pipeline was canceled. The branch comes from a fork so it
> should need approval to run.
> > https://gitlab.com/petsc/petsc/-/merge_requests/3707
> > Matthew Knepley <knepley at gmail.com> writes:
> > > Thanks,
> > > Matt
> > > What most experimenters take for granted before they begin their
> > > experiments is infinitely more interesting than any results to which
> their
> > > experiments lead.
> > > -- Norbert Wiener
> > > https://www.cse.buffalo.edu/~knepley/ <
> http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210312/487389c5/attachment-0001.html>
