[petsc-dev] problem registering a new solver
Mark Adams
mfadams at lbl.gov
Wed Mar 3 07:35:48 CST 2021
On Tue, Mar 2, 2021 at 5:22 PM Matthew Knepley <knepley at gmail.com> wrote:
> Maybe there is a bug in the Register() code.
Humm, but I just add one more registration ....
ierr = MatSolverTypeRegister(MATSOLVERPETSC, MATSEQAIJ,
MAT_FACTOR_LU,MatGetFactor_seqaij_petsc);CHKERRQ(ierr);
MAT_FACTOR_CHOLESKY,MatGetFactor_seqaij_petsc);CHKERRQ(ierr);
MAT_FACTOR_ILU,MatGetFactor_seqaij_petsc);CHKERRQ(ierr);
MAT_FACTOR_ICC,MatGetFactor_seqaij_petsc);CHKERRQ(ierr);
* ierr = MatSolverTypeRegister(MATSOLVERPETSC, MATSEQAIJ,
MAT_FACTOR_LUBAND,MatGetFactor_seqaij_petsc);CHKERRQ(ierr);*
luband is a little different in that it does not touch PC, there is no
-pc_type luband (now), while the others are pc_types. But that should not
matter.
> Matt
> On Tue, Mar 2, 2021 at 4:43 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I see the problem, but not the solution. I put a print statement
>> in MatSolverTypeDestroy and see:
>> MatSolverTypeDestroy seqaij inext->next=0x7fb4a9114c70
>> inext=0x7fb4a9113c70
>> before it fails. This seqaij node seems to be pointing to itself. If I
>> remove my registration call and it works and I see this from my print
>> statement:
>> MatSolverTypeDestroy seqaij inext->next=0x7fe811827270
>> inext=0x7fe811826270
>> MatSolverTypeDestroy seqaijperm inext->next=0x7fe811909c70
>> inext=0x7fe811827270
>> MatSolverTypeDestroy constantdiagonal inext->next=0x7fe81190ac70
>> inext=0x7fe811909c70
>> On Tue, Mar 2, 2021 at 3:42 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> I am trying to add a band solver to PETSc (later to be moved to Cuda and
>>> Kokkos) and I have started by adding some types and a copy of the current
>>> LU as placeholders. I register with:
>>> And that is about all that I do that can have any effect at this point.
>>> I add a switch in MatGetFactor_seqaij_petsc on (ftype ==
>>> MAT_FACTOR_LUBAND) to set the symbolic factorization
>>> method (*B)->ops->lufactorsymbolic = MatLUBandFactorSymbolic_SeqAIJ; But
>>> this is not called (I verified this) because I don't know how to
>>> get MatGetFactor_seqaij_petsc to receive ftype == MAT_FACTOR_LUBAND. (I
>>> need help on this to)
>>> Anyway, I would hope that these changes would not do anything but I get
>>> an error (appended).
>>> It is failing in MatSolverTypeDestroy on this second PetscFree:
>>> while (inext) {
>>> ierr = PetscFree(inext->mtype);CHKERRQ(ierr);
>>> iprev = inext;
>>> inext = inext->next;
>>> ierr = PetscFree(iprev);CHKERRQ(ierr);
>>> I tried to clone LU here, but I clearly missed something.
>>> Any ideas?
>>> And I just made an MR for this if you want to look at the code.
>>> Thanks,
>>> Mark
>>> Number of SNES iterations = 2
>>> [0]PETSC ERROR: PetscTrFreeDefault() called from MatSolverTypeDestroy()
>>> line 4513 in /Users/markadams/Codes/petsc/src/mat/interface/matrix.c
>>> [0]PETSC ERROR: Block [id=0(48)] at address 0x7fb7fb8f7620 is corrupted
>>> (probably write past end of array)
>>> [0]PETSC ERROR: Block allocated in MatSolverTypeRegister() line 4382 in
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Memory corruption:
>>> https://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
>>> [0]PETSC ERROR: Corrupted memory
>>> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Development GIT revision: v3.14.4-739-g575f931ef8
>>> GIT Date: 2021-03-02 13:38:55 -0500
>>> [0]PETSC ERROR: ./ex19 on a arch-macosx-gnu-g named MarksMac-302.local
>>> by markadams Tue Mar 2 15:28:41 2021
>>> [0]PETSC ERROR: Configure options
>>> --with-mpi-dir=/usr/local/Cellar/mpich/3.3.2_1 COPTFLAGS="-g -O0"
>>> CXXOPTFLAGS="-g -O0" --download-metis=1 --download-parmetis=1
>>> --download-kokkos=1 --download-kokkos-kernels=1 --download-p4est=1
>>> --with-zlib=1 --download-superlu_dist --download-superlu --with-make-np=4
>>> --download-hdf5=1 -with-cuda=0 --with-x=0 --with-debugging=1
>>> PETSC_ARCH=arch-macosx-gnu-g --with-64-bit-indices=0 --with-openmp=0
>>> --with-ctable=0
>>> [0]PETSC ERROR: #1 PetscTrFreeDefault() line 310 in
>>> /Users/markadams/Codes/petsc/src/sys/memory/mtr.c
>>> [0]PETSC ERROR: #2 MatSolverTypeDestroy() line 4513 in
>>> [0]PETSC ERROR: #3 MatFinalizePackage() line 57 in
>>> /Users/markadams/Codes/petsc/src/mat/interface/dlregismat.c
>>> [0]PETSC ERROR: #4 PetscRegisterFinalizeAll() line 389 in
>>> /Users/markadams/Codes/petsc/src/sys/objects/destroy.c
>>> [0]PETSC ERROR: #5 PetscFinalize() line 1474 in
>>> /Users/markadams/Codes/petsc/src/sys/objects/pinit.c
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210303/89e51e12/attachment.html>
