[petsc-dev] problem registering a new solver
Tue Mar 2 16:22:10 CST 2021
Maybe there is a bug in the Register() code.
   Matt
On Tue, Mar 2, 2021 at 4:43 PM Mark Adams <mfadams at lbl.gov> wrote:
> I see the problem, but not the solution. I put a print statement
> in MatSolverTypeDestroy and see:
> MatSolverTypeDestroy seqaij inext->next=0x7fb4a9114c70 inext=0x7fb4a9113c70
> before it fails. This seqaij node seems to be pointing to itself. If I
> remove my registration call and it works and I see this from my print
> statement:
> MatSolverTypeDestroy seqaij inext->next=0x7fe811827270 inext=0x7fe811826270
> MatSolverTypeDestroy seqaijperm inext->next=0x7fe811909c70
> inext=0x7fe811827270
> MatSolverTypeDestroy constantdiagonal inext->next=0x7fe81190ac70
> inext=0x7fe811909c70
> On Tue, Mar 2, 2021 at 3:42 PM Mark Adams <mfadams at lbl.gov> wrote:
>> I am trying to add a band solver to PETSc (later to be moved to Cuda and
>> Kokkos) and I have started by adding some types and a copy of the current
>> LU as placeholders. I register with:
>>  ierr = MatSolverTypeRegister(MATSOLVERPETSC, MATSEQAIJ,
>>  MAT_FACTOR_LUBAND,MatGetFactor_seqaij_petsc);CHKERRQ(ierr);
>> And that is about all that I do that can have any effect at this point. I
>> add a switch in  MatGetFactor_seqaij_petsc on (ftype == MAT_FACTOR_LUBAND)
>> to set the symbolic factorization method (*B)->ops->lufactorsymbolic  =
>> MatLUBandFactorSymbolic_SeqAIJ; But this is not called (I verified this)
>> because I don't know how to get MatGetFactor_seqaij_petsc to receive ftype
>> == MAT_FACTOR_LUBAND. (I need help on this to)
>> Anyway, I would hope that these changes would not do anything but I get
>> an error (appended).
>> It is failing in MatSolverTypeDestroy on this second PetscFree:
>>     while (inext) {
>>       ierr = PetscFree(inext->mtype);CHKERRQ(ierr);
>>       iprev = inext;
>>       inext = inext->next;
>>       ierr = PetscFree(iprev);CHKERRQ(ierr);
>> I tried to clone LU here, but I clearly missed something.
>> Any ideas?
>> And I just made  an MR for this if you want to look at the code.
>> Thanks,
>> Mark
>> Number of SNES iterations = 2
>> [0]PETSC ERROR: PetscTrFreeDefault() called from MatSolverTypeDestroy()
>> line 4513 in /Users/markadams/Codes/petsc/src/mat/interface/matrix.c
>> [0]PETSC ERROR: Block [id=0(48)] at address 0x7fb7fb8f7620 is corrupted
>> (probably write past end of array)
>> [0]PETSC ERROR: Block allocated in MatSolverTypeRegister() line 4382 in
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Memory corruption:
>> https://www.mcs.anl.gov/petsc/documentation/installation.html#valgrind
>> [0]PETSC ERROR: Corrupted memory
>> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Development GIT revision: v3.14.4-739-g575f931ef8
>>  GIT Date: 2021-03-02 13:38:55 -0500
>> [0]PETSC ERROR: ./ex19 on a arch-macosx-gnu-g named MarksMac-302.local by
>> markadams Tue Mar  2 15:28:41 2021
>> [0]PETSC ERROR: Configure options
>> --with-mpi-dir=/usr/local/Cellar/mpich/3.3.2_1 COPTFLAGS="-g -O0"
>> CXXOPTFLAGS="-g -O0" --download-metis=1 --download-parmetis=1
>> --download-kokkos=1 --download-kokkos-kernels=1 --download-p4est=1
>> --with-zlib=1 --download-superlu_dist --download-superlu --with-make-np=4
>> --download-hdf5=1 -with-cuda=0 --with-x=0 --with-debugging=1
>> PETSC_ARCH=arch-macosx-gnu-g --with-64-bit-indices=0 --with-openmp=0
>> --with-ctable=0
>> [0]PETSC ERROR: #1 PetscTrFreeDefault() line 310 in
>> /Users/markadams/Codes/petsc/src/sys/memory/mtr.c
>> [0]PETSC ERROR: #2 MatSolverTypeDestroy() line 4513 in
>> [0]PETSC ERROR: #3 MatFinalizePackage() line 57 in
>> /Users/markadams/Codes/petsc/src/mat/interface/dlregismat.c
>> [0]PETSC ERROR: #4 PetscRegisterFinalizeAll() line 389 in
>> /Users/markadams/Codes/petsc/src/sys/objects/destroy.c
>> [0]PETSC ERROR: #5 PetscFinalize() line 1474 in
>> /Users/markadams/Codes/petsc/src/sys/objects/pinit.c
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210302/3b2622fc/attachment.html>
