[petsc-dev] Commit squashing in MR
Barry Smith bsmith at petsc.dev
Tue Mar 2 22:02:31 CST 2021
> On Mar 2, 2021, at 9:24 PM, Mark Adams <mfadams at lbl.gov> wrote:
> Ah, 'git graph' I will try that next time.
> I use 'git rebase -i HEAD~N', but you need an N.
> After you 'git rebase origin/main' you get other commits interspersed in with yours,
   I do not get this. I thought that rebasing with main put all the main changes in before your commits. I have never seen any interspersed, so I do not understand this.
  Barry
> so I try to rebase -i before rebasing over main. Then rebase over main and you have a clean and updated branch.
> Pick N to be large enough to cover the commits that you want to clean up. Don't touch the ones that are not yours from main, the last time you rebased over main.
> On Tue, Mar 2, 2021 at 10:02 PM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
> I am a naive git user, so I use interactive git rebase.  Suppose I am on the branch I want to modify,
> 1) Use git graph to locate an upstream commit to be used as the base
> $ git graph
> * 0d5433e9 (HEAD -> jczhang/sf-change-api) SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
> * e7314fbb SF: add an MPI_Op argument to SFBcast
> * 83df288d Replace MPIU_REPLACE with MPI_REPLACE
> *   b434c516 Merge branch 'barry/2021-02-02/petscsf-communication-specific' into 'main'
> | * 62152ded (barry/2021-02-02/petscsf-communication-specific) PetscSFView() never called viewer for the specific type (bug), hence many output files were incorrect.
> * |   a4f5d9b4 Merge branch 'jose/upgrade-magma' into 'main'
> 2) Suppose we choose b434c516 as the base. All commits we want to squash are after it.  Do interactive git rebase. It shows a screen for you to edit.  Read the help, which is helpful for new users
>   $ git rebase -i b434c516
> pick 83df288d Replace MPIU_REPLACE with MPI_REPLACE
> pick e7314fbb SF: add an MPI_Op argument to SFBcast
> pick 0d5433e9 SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
> # Rebase b434c516..0d5433e9 onto b434c516 (3 commands)
> # Commands:
> # p, pick <commit> = use commit
> # r, reword <commit> = use commit, but edit the commit message
> # e, edit <commit> = use commit, but stop for amending
> # s, squash <commit> = use commit, but meld into previous commit
> # f, fixup <commit> = like "squash", but discard this commit's log message
> # x, exec <command> = run command (the rest of the line) using shell
> # b, break = stop here (continue rebase later with 'git rebase --continue')
> # d, drop <commit> = remove commit
> # l, label <label> = label current HEAD with a name
> # t, reset <label> = reset HEAD to a label
> # m, merge [-C <commit> | -c <commit>] <label> [# <oneline>]
> # .       create a merge commit using the original merge commit's
> # .       message (or the oneline, if no original merge commit was
> # .       specified). Use -c <commit> to reword the commit message.
> # These lines can be re-ordered; they are executed from top to bottom.
> # If you remove a line here THAT COMMIT WILL BE LOST.
> # However, if you remove everything, the rebase will be aborted.
> # Note that empty commits are commented out
> 3) Suppose we want to squash the last two commits to 83df288d, replace their pick with s (or f, see the help for difference), save and exit the screen
> s e7314fbb SF: add an MPI_Op argument to SFBcast
> s 0d5433e9 SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
> A new screen shows up
> # This is a combination of 3 commits.
> # This is the 1st commit message:
> Since we believe all MPI implementations support MPI_REPLACE
> # This is the commit message #2:
> # This is the commit message #3:
> # Please enter the commit message for your changes. Lines starting
> # with '#' will be ignored, and an empty message aborts the commit.
> 4) Edit the commit message as you want, save and exit, done!
> --Junchao Zhang
> On Tue, Mar 2, 2021 at 6:19 PM Blaise A Bourdin <bourdin at lsu.edu <mailto:bourdin at lsu.edu>> wrote:
> Hi,
> This is not technically a petsc question.
> It would be great to have a short section in the PETSc integration workflow document explaining how to squash commits in a MR for git-impaired developers like me.
> Anybody wants to pitch in, or explain me how to do this?
> Regards,
> Blaise
> A.K. & Shirley Barton Professor of  Mathematics
> Adjunct Professor of Mechanical Engineering
> Adjunct of the Center for Computation & Technology
> Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin <http://www.math.lsu.edu/~bourdin>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210302/a92f58f4/attachment.html>
