[petsc-dev] Commit squashing in MR
Mark Adams
mfadams at lbl.gov
Tue Mar 2 21:24:40 CST 2021
Ah, 'git graph' I will try that next time.
I use 'git rebase -i HEAD~N', but you need an N.
After you 'git rebase origin/main' you get other commits interspersed in
with yours, so I try to rebase -i before rebasing over main. Then rebase
over main and you have a clean and updated branch.
Pick N to be large enough to cover the commits that you want to clean up.
Don't touch the ones that are not yours from main, the last time you
rebased over main.
On Tue, Mar 2, 2021 at 10:02 PM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> I am a naive git user, so I use interactive git rebase. Suppose I am on
> the branch I want to modify,
> 1) Use git graph to locate an upstream commit to be used as the base
> $ git graph
> * 0d5433e9 (HEAD -> jczhang/sf-change-api) SF: rename SFCreateEmbeddedSF
> to SFCreateEmbeddedRootSF
> * e7314fbb SF: add an MPI_Op argument to SFBcast
> * 83df288d Replace MPIU_REPLACE with MPI_REPLACE
> * b434c516 Merge branch
> 'barry/2021-02-02/petscsf-communication-specific' into 'main'
> | * 62152ded (barry/2021-02-02/petscsf-communication-specific)
> PetscSFView() never called viewer for the specific type (bug), hence many
> output files were incorrect.
> * | a4f5d9b4 Merge branch 'jose/upgrade-magma' into 'main'
> 2) Suppose we choose b434c516 as the base. All commits we want to squash
> are after it. Do interactive git rebase. It shows a screen for you to
> edit. Read the help, which is helpful for new users
> $ git rebase -i b434c516
> pick 83df288d Replace MPIU_REPLACE with MPI_REPLACE
> pick e7314fbb SF: add an MPI_Op argument to SFBcast
> pick 0d5433e9 SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
> # Rebase b434c516..0d5433e9 onto b434c516 (3 commands)
> # Commands:
> # p, pick <commit> = use commit
> # r, reword <commit> = use commit, but edit the commit message
> # e, edit <commit> = use commit, but stop for amending
> # s, squash <commit> = use commit, but meld into previous commit
> # f, fixup <commit> = like "squash", but discard this commit's log message
> # x, exec <command> = run command (the rest of the line) using shell
> # b, break = stop here (continue rebase later with 'git rebase --continue')
> # d, drop <commit> = remove commit
> # l, label <label> = label current HEAD with a name
> # t, reset <label> = reset HEAD to a label
> # m, merge [-C <commit> | -c <commit>] <label> [# <oneline>]
> # . create a merge commit using the original merge commit's
> # . message (or the oneline, if no original merge commit was
> # . specified). Use -c <commit> to reword the commit message.
> # These lines can be re-ordered; they are executed from top to bottom.
> # If you remove a line here THAT COMMIT WILL BE LOST.
> # However, if you remove everything, the rebase will be aborted.
> # Note that empty commits are commented out
> 3) Suppose we want to squash the last two commits to 83df288d, replace
> their pick with s (or f, see the help for difference), save and exit the
> screen
> s e7314fbb SF: add an MPI_Op argument to SFBcast
> s 0d5433e9 SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
> A new screen shows up
> # This is a combination of 3 commits.
> # This is the 1st commit message:
> Since we believe all MPI implementations support MPI_REPLACE
> # This is the commit message #2:
> # This is the commit message #3:
> # Please enter the commit message for your changes. Lines starting
> # with '#' will be ignored, and an empty message aborts the commit.
> 4) Edit the commit message as you want, save and exit, done!
> --Junchao Zhang
> On Tue, Mar 2, 2021 at 6:19 PM Blaise A Bourdin <bourdin at lsu.edu> wrote:
>> Hi,
>> This is not technically a petsc question.
>> It would be great to have a short section in the PETSc integration
>> workflow document explaining how to squash commits in a MR for git-impaired
>> developers like me.
>> Anybody wants to pitch in, or explain me how to do this?
>> Regards,
>> Blaise
>> A.K. & Shirley Barton Professor of Mathematics
>> Adjunct Professor of Mechanical Engineering
>> Adjunct of the Center for Computation & Technology
>> Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803,
>> USA
>> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 Web
>> http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210302/c993bddf/attachment.html>
