[petsc-dev] Commit squashing in MR
    Jacob Faibussowitsch
    jacob.fai at gmail.com
    Tue Mar  2 22:09:38 CST 2021
>   I do not get this. I thought that rebasing with main put all the main changes in before your commits. I have never seen any interspersed, so I do not understand this.
Mark, do you rebase your branch over main first or do you merge main intro your branch to update it? If you rebase, you can pick an N such that you only get your commits from the branch.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
> On Mar 2, 2021, at 22:02, Barry Smith <bsmith at petsc.dev> wrote:
>> On Mar 2, 2021, at 9:24 PM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> Ah, 'git graph' I will try that next time.
>> I use 'git rebase -i HEAD~N', but you need an N.
>> After you 'git rebase origin/main' you get other commits interspersed in with yours,
>   Barry
>> so I try to rebase -i before rebasing over main. Then rebase over main and you have a clean and updated branch.
>> Pick N to be large enough to cover the commits that you want to clean up. Don't touch the ones that are not yours from main, the last time you rebased over main.
>> On Tue, Mar 2, 2021 at 10:02 PM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>> I am a naive git user, so I use interactive git rebase.  Suppose I am on the branch I want to modify,
>> 1) Use git graph to locate an upstream commit to be used as the base
>> $ git graph
>> * 0d5433e9 (HEAD -> jczhang/sf-change-api) SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
>> * e7314fbb SF: add an MPI_Op argument to SFBcast
>> * 83df288d Replace MPIU_REPLACE with MPI_REPLACE
>> *   b434c516 Merge branch 'barry/2021-02-02/petscsf-communication-specific' into 'main'
>> | * 62152ded (barry/2021-02-02/petscsf-communication-specific) PetscSFView() never called viewer for the specific type (bug), hence many output files were incorrect.
>> * |   a4f5d9b4 Merge branch 'jose/upgrade-magma' into 'main'
>> 2) Suppose we choose b434c516 as the base. All commits we want to squash are after it.  Do interactive git rebase. It shows a screen for you to edit.  Read the help, which is helpful for new users
>>   $ git rebase -i b434c516
>> pick 83df288d Replace MPIU_REPLACE with MPI_REPLACE
>> pick e7314fbb SF: add an MPI_Op argument to SFBcast
>> pick 0d5433e9 SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
>> # Rebase b434c516..0d5433e9 onto b434c516 (3 commands)
>> # Commands:
>> # p, pick <commit> = use commit
>> # r, reword <commit> = use commit, but edit the commit message
>> # e, edit <commit> = use commit, but stop for amending
>> # s, squash <commit> = use commit, but meld into previous commit
>> # f, fixup <commit> = like "squash", but discard this commit's log message
>> # x, exec <command> = run command (the rest of the line) using shell
>> # b, break = stop here (continue rebase later with 'git rebase --continue')
>> # d, drop <commit> = remove commit
>> # l, label <label> = label current HEAD with a name
>> # t, reset <label> = reset HEAD to a label
>> # m, merge [-C <commit> | -c <commit>] <label> [# <oneline>]
>> # .       create a merge commit using the original merge commit's
>> # .       message (or the oneline, if no original merge commit was
>> # .       specified). Use -c <commit> to reword the commit message.
>> # These lines can be re-ordered; they are executed from top to bottom.
>> # If you remove a line here THAT COMMIT WILL BE LOST.
>> # However, if you remove everything, the rebase will be aborted.
>> # Note that empty commits are commented out
>> 3) Suppose we want to squash the last two commits to 83df288d, replace their pick with s (or f, see the help for difference), save and exit the screen
>> s e7314fbb SF: add an MPI_Op argument to SFBcast
>> s 0d5433e9 SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
>> A new screen shows up
>> # This is a combination of 3 commits.
>> # This is the 1st commit message:
>> Since we believe all MPI implementations support MPI_REPLACE
>> # This is the commit message #2:
>> # This is the commit message #3:
>> # Please enter the commit message for your changes. Lines starting
>> # with '#' will be ignored, and an empty message aborts the commit.
>> 4) Edit the commit message as you want, save and exit, done!
>> --Junchao Zhang
>> On Tue, Mar 2, 2021 at 6:19 PM Blaise A Bourdin <bourdin at lsu.edu <mailto:bourdin at lsu.edu>> wrote:
>> Hi,
>> This is not technically a petsc question.
>> It would be great to have a short section in the PETSc integration workflow document explaining how to squash commits in a MR for git-impaired developers like me.
>> Anybody wants to pitch in, or explain me how to do this?
>> Regards,
>> Blaise
>> A.K. & Shirley Barton Professor of  Mathematics
>> Adjunct Professor of Mechanical Engineering
>> Adjunct of the Center for Computation & Technology
>> Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA
>> Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin <http://www.math.lsu.edu/~bourdin>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210302/722ee600/attachment-0001.html>
