[petsc-dev] Commit squashing in MR
Junchao Zhang
junchao.zhang at gmail.com
Tue Mar 2 21:02:36 CST 2021
I am a naive git user, so I use interactive git rebase. Suppose I am on
the branch I want to modify,
1) Use git graph to locate an upstream commit to be used as the base
$ git graph
* 0d5433e9 (HEAD -> jczhang/sf-change-api) SF: rename SFCreateEmbeddedSF to
SFCreateEmbeddedRootSF
* e7314fbb SF: add an MPI_Op argument to SFBcast
* 83df288d Replace MPIU_REPLACE with MPI_REPLACE
* b434c516 Merge branch 'barry/2021-02-02/petscsf-communication-specific'
into 'main'
| * 62152ded (barry/2021-02-02/petscsf-communication-specific)
PetscSFView() never called viewer for the specific type (bug), hence many
output files were incorrect.
* | a4f5d9b4 Merge branch 'jose/upgrade-magma' into 'main'
2) Suppose we choose b434c516 as the base. All commits we want to squash
are after it. Do interactive git rebase. It shows a screen for you to
edit. Read the help, which is helpful for new users
$ git rebase -i b434c516
pick 83df288d Replace MPIU_REPLACE with MPI_REPLACE
pick e7314fbb SF: add an MPI_Op argument to SFBcast
pick 0d5433e9 SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
# Rebase b434c516..0d5433e9 onto b434c516 (3 commands)
# Commands:
# p, pick <commit> = use commit
# r, reword <commit> = use commit, but edit the commit message
# e, edit <commit> = use commit, but stop for amending
# s, squash <commit> = use commit, but meld into previous commit
# f, fixup <commit> = like "squash", but discard this commit's log message
# x, exec <command> = run command (the rest of the line) using shell
# b, break = stop here (continue rebase later with 'git rebase --continue')
# d, drop <commit> = remove commit
# l, label <label> = label current HEAD with a name
# t, reset <label> = reset HEAD to a label
# m, merge [-C <commit> | -c <commit>] <label> [# <oneline>]
# . create a merge commit using the original merge commit's
# . message (or the oneline, if no original merge commit was
# . specified). Use -c <commit> to reword the commit message.
# These lines can be re-ordered; they are executed from top to bottom.
# If you remove a line here THAT COMMIT WILL BE LOST.
# However, if you remove everything, the rebase will be aborted.
# Note that empty commits are commented out
3) Suppose we want to squash the last two commits to 83df288d, replace
their pick with s (or f, see the help for difference), save and exit the
screen
s e7314fbb SF: add an MPI_Op argument to SFBcast
s 0d5433e9 SF: rename SFCreateEmbeddedSF to SFCreateEmbeddedRootSF
A new screen shows up
# This is a combination of 3 commits.
# This is the 1st commit message:
Since we believe all MPI implementations support MPI_REPLACE
# This is the commit message #2:
# This is the commit message #3:
# Please enter the commit message for your changes. Lines starting
# with '#' will be ignored, and an empty message aborts the commit.
4) Edit the commit message as you want, save and exit, done!
--Junchao Zhang
On Tue, Mar 2, 2021 at 6:19 PM Blaise A Bourdin <bourdin at lsu.edu> wrote:
> Hi,
> This is not technically a petsc question.
> It would be great to have a short section in the PETSc integration
> workflow document explaining how to squash commits in a MR for git-impaired
> developers like me.
> Anybody wants to pitch in, or explain me how to do this?
> Regards,
> Blaise
> A.K. & Shirley Barton Professor of Mathematics
> Adjunct Professor of Mechanical Engineering
> Adjunct of the Center for Computation & Technology
> Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803,
> USA
> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 Web
> http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210302/804543f8/attachment-0001.html>
