[petsc-dev] VecGetArrayAndMemType
    Mark Adams
    mfadams at lbl.gov
    Wed Jun 23 16:04:26 CDT 2021
I also tried commenting out the second VecView, so there is just one step
in the file, and the .h5 file is only 8 bytes smaller and the .xmf file
goes from 5373  bytes to 3090 bytes.
On Wed, Jun 23, 2021 at 4:01 PM Mark Adams <mfadams at lbl.gov> wrote:
> It is not a device issue but it is a regression.
> Landau ex1 is tiny and just calls VecView before and after the TSsolve,
> which is one time step. If you add "*-dm_view hdf5:f.h5 -vec_view
> hdf5:f.h5::append -dm_landau_Ez 10.*" to landau/ex1 (see below), you get
> an h5 file with two time steps, as it should be.
> This is a huge electric field, Ez=10, which makes the electron
> distribution (u_e) get visibly pulled off center.
> In Visit, both time steps have identical data that is clearly after the
> solve and not the initial condition (see attached).
> I ran this again with -ex1_ts_max_steps 0 and get the expected result of
> two steps/frames with the symmetric initial condition in both. THis is
> correct behavior.
> Any ideas?
> Thanks
> diff --git a/src/ts/utils/dmplexlandau/tutorials/ex1.c
> b/src/ts/utils/dmplexlandau/tutorials/ex1.c
> index 9e4c8f1b61..31dfda2fad 100644
> --- a/src/ts/utils/dmplexlandau/tutorials/ex1.c
> +++ b/src/ts/utils/dmplexlandau/tutorials/ex1.c
> @@ -66,6 +66,6 @@ int main(int argc, char **argv)
>    test:
>      suffix: 0
>      requires: p4est !complex
> -    args: -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type
> p4est -dm_landau_ion_masses 2,4 -dm_landau_ion_charges 1,18
> -dm_landau_thermal_temps 5,5,.5 -dm_landau_n 1.00018,1,1e-5 -dm_landau_n_0
> 1e20 -ex1_ts_monitor -ex1_snes_rtol 1.e-14 -ex1_snes_stol 1.e-14
> -ex1_snes_monitor -ex1_snes_converged_reason -ex1_ts_type arkimex
> -ex1_ts_arkimex_type 1bee -ex1_ts_max_snes_failures -1 -ex1_ts_rtol 1e-1
> -ex1_ts_dt 1.e-1 -ex1_ts_max_time 1 -ex1_ts_adapt_clip .5,1.25
> -ex1_ts_adapt_scale_solve_failed 0.75
> -ex1_ts_adapt_time_step_increase_delay 5 -ex1_ts_max_steps 1 -ex1_pc_type
> lu -ex1_ksp_type preonly -dm_landau_amr_levels_max 7
> -dm_landau_domain_radius 5 -dm_landau_amr_re_levels 0 -dm_landau_re_radius
> 1 -dm_landau_amr_z_refine1 1 -dm_landau_amr_z_refine2 0
> -dm_landau_amr_post_refine 0 -dm_landau_z_radius1 .1 -dm_landau_z_radius2
> .1 -dm_refine 1 -dm_landau_gpu_assembly false
> +    args: -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type
> .1 -dm_refine 1 -dm_landau_gpu_assembly false *-dm_view hdf5:f.h5
> -vec_view hdf5:f.h5::append -dm_landau_Ez 10.*
>  TEST*/
> On Wed, Jun 23, 2021 at 1:38 PM Mark Adams <mfadams at lbl.gov> wrote:
>> Landau ex1 should work. I will test.
>> On Wed, Jun 23, 2021 at 10:47 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Wed, Jun 23, 2021 at 10:44 AM Junchao Zhang <junchao.zhang at gmail.com>
>>> wrote:
>>>> Use VecGetArrayRead/Write() to get up-to-date host pointers to the
>>>> vector array.
>>> I think Mark is saying that those are not working. We do call
>>> VecGetArrayRead() in the HDF5 code.
>>> Mark, it seem like a small broken code is necessary.
>>>   Thanks,
>>>     Matt
>>>> --Junchao Zhang
>>>> On Wed, Jun 23, 2021 at 9:15 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> First, there seem to be two pages for VecGetArrayAndMemType (one has a
>>>>> pointer to the other).
>>>>> So I need to get a CPU array for HDF5 viewing. Totally broken for
>>>>> devices.
>>>>> I don't find a VecGetArrayCpu[HOST] that does the right thing.
>>>>> Perhaps have VecGetArrayAndMemType return a valid CPU pointer when
>>>>> "mtype==NULL"?
>>>>> Mark
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210623/5681fa80/attachment.html>
