[petsc-dev] VecGetArrayAndMemType
    Junchao Zhang
    junchao.zhang at gmail.com
    Wed Jun 23 22:14:31 CDT 2021
Mark,
  I am not sure what your problem is.  If it is a regression, can you
bisect it?
--Junchao Zhang
On Wed, Jun 23, 2021 at 4:04 PM Mark Adams <mfadams at lbl.gov> wrote:
> I also tried commenting out the second VecView, so there is just one step
> in the file, and the .h5 file is only 8 bytes smaller and the .xmf file
> goes from 5373  bytes to 3090 bytes.
> On Wed, Jun 23, 2021 at 4:01 PM Mark Adams <mfadams at lbl.gov> wrote:
>> It is not a device issue but it is a regression.
>> Landau ex1 is tiny and just calls VecView before and after the TSsolve,
>> which is one time step. If you add "*-dm_view hdf5:f.h5 -vec_view
>> hdf5:f.h5::append -dm_landau_Ez 10.*" to landau/ex1 (see below), you get
>> an h5 file with two time steps, as it should be.
>> This is a huge electric field, Ez=10, which makes the electron
>> distribution (u_e) get visibly pulled off center.
>> In Visit, both time steps have identical data that is clearly after the
>> solve and not the initial condition (see attached).
>> I ran this again with -ex1_ts_max_steps 0 and get the expected result of
>> two steps/frames with the symmetric initial condition in both. THis is
>> correct behavior.
>> Any ideas?
>> Thanks
>> diff --git a/src/ts/utils/dmplexlandau/tutorials/ex1.c
>> b/src/ts/utils/dmplexlandau/tutorials/ex1.c
>> index 9e4c8f1b61..31dfda2fad 100644
>> --- a/src/ts/utils/dmplexlandau/tutorials/ex1.c
>> +++ b/src/ts/utils/dmplexlandau/tutorials/ex1.c
>> @@ -66,6 +66,6 @@ int main(int argc, char **argv)
>>    test:
>>      suffix: 0
>>      requires: p4est !complex
>> -    args: -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type
>> p4est -dm_landau_ion_masses 2,4 -dm_landau_ion_charges 1,18
>> -dm_landau_thermal_temps 5,5,.5 -dm_landau_n 1.00018,1,1e-5 -dm_landau_n_0
>> 1e20 -ex1_ts_monitor -ex1_snes_rtol 1.e-14 -ex1_snes_stol 1.e-14
>> -ex1_snes_monitor -ex1_snes_converged_reason -ex1_ts_type arkimex
>> -ex1_ts_arkimex_type 1bee -ex1_ts_max_snes_failures -1 -ex1_ts_rtol 1e-1
>> -ex1_ts_dt 1.e-1 -ex1_ts_max_time 1 -ex1_ts_adapt_clip .5,1.25
>> -ex1_ts_adapt_scale_solve_failed 0.75
>> -ex1_ts_adapt_time_step_increase_delay 5 -ex1_ts_max_steps 1 -ex1_pc_type
>> lu -ex1_ksp_type preonly -dm_landau_amr_levels_max 7
>> -dm_landau_domain_radius 5 -dm_landau_amr_re_levels 0 -dm_landau_re_radius
>> 1 -dm_landau_amr_z_refine1 1 -dm_landau_amr_z_refine2 0
>> -dm_landau_amr_post_refine 0 -dm_landau_z_radius1 .1 -dm_landau_z_radius2
>> .1 -dm_refine 1 -dm_landau_gpu_assembly false
>> +    args: -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type
>> .1 -dm_refine 1 -dm_landau_gpu_assembly false *-dm_view hdf5:f.h5
>> -vec_view hdf5:f.h5::append -dm_landau_Ez 10.*
>>  TEST*/
>> On Wed, Jun 23, 2021 at 1:38 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> Landau ex1 should work. I will test.
>>> On Wed, Jun 23, 2021 at 10:47 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Jun 23, 2021 at 10:44 AM Junchao Zhang <junchao.zhang at gmail.com>
>>>> wrote:
>>>>> Use VecGetArrayRead/Write() to get up-to-date host pointers to the
>>>>> vector array.
>>>> I think Mark is saying that those are not working. We do call
>>>> VecGetArrayRead() in the HDF5 code.
>>>> Mark, it seem like a small broken code is necessary.
>>>>   Thanks,
>>>>     Matt
>>>>> --Junchao Zhang
>>>>> On Wed, Jun 23, 2021 at 9:15 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>>>> First, there seem to be two pages for VecGetArrayAndMemType (one has
>>>>>> a pointer to the other).
>>>>>> So I need to get a CPU array for HDF5 viewing. Totally broken for
>>>>>> devices.
>>>>>> I don't find a VecGetArrayCpu[HOST] that does the right thing.
>>>>>> Perhaps have VecGetArrayAndMemType return a valid CPU pointer when
>>>>>> "mtype==NULL"?
>>>>>> Mark
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210623/f3cf9d67/attachment.html>
