[petsc-dev] VecGetArrayAndMemType
Mark Adams
mfadams at lbl.gov
Wed Jun 23 15:01:55 CDT 2021
It is not a device issue but it is a regression.
Landau ex1 is tiny and just calls VecView before and after the TSsolve,
which is one time step. If you add "*-dm_view hdf5:f.h5 -vec_view
hdf5:f.h5::append -dm_landau_Ez 10.*" to landau/ex1 (see below), you get an
h5 file with two time steps, as it should be.
This is a huge electric field, Ez=10, which makes the electron distribution
(u_e) get visibly pulled off center.
In Visit, both time steps have identical data that is clearly after the
solve and not the initial condition (see attached).
I ran this again with -ex1_ts_max_steps 0 and get the expected result of
two steps/frames with the symmetric initial condition in both. THis is
correct behavior.
Any ideas?
Thanks
diff --git a/src/ts/utils/dmplexlandau/tutorials/ex1.c
b/src/ts/utils/dmplexlandau/tutorials/ex1.c
index 9e4c8f1b61..31dfda2fad 100644
--- a/src/ts/utils/dmplexlandau/tutorials/ex1.c
+++ b/src/ts/utils/dmplexlandau/tutorials/ex1.c
@@ -66,6 +66,6 @@ int main(int argc, char **argv)
test:
suffix: 0
requires: p4est !complex
- args: -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type
p4est -dm_landau_ion_masses 2,4 -dm_landau_ion_charges 1,18
-dm_landau_thermal_temps 5,5,.5 -dm_landau_n 1.00018,1,1e-5 -dm_landau_n_0
1e20 -ex1_ts_monitor -ex1_snes_rtol 1.e-14 -ex1_snes_stol 1.e-14
-ex1_snes_monitor -ex1_snes_converged_reason -ex1_ts_type arkimex
-ex1_ts_arkimex_type 1bee -ex1_ts_max_snes_failures -1 -ex1_ts_rtol 1e-1
-ex1_ts_dt 1.e-1 -ex1_ts_max_time 1 -ex1_ts_adapt_clip .5,1.25
-ex1_ts_adapt_scale_solve_failed 0.75
-ex1_ts_adapt_time_step_increase_delay 5 -ex1_ts_max_steps 1 -ex1_pc_type
lu -ex1_ksp_type preonly -dm_landau_amr_levels_max 7
-dm_landau_domain_radius 5 -dm_landau_amr_re_levels 0 -dm_landau_re_radius
1 -dm_landau_amr_z_refine1 1 -dm_landau_amr_z_refine2 0
-dm_landau_amr_post_refine 0 -dm_landau_z_radius1 .1 -dm_landau_z_radius2
.1 -dm_refine 1 -dm_landau_gpu_assembly false
+ args: -petscspace_degree 3 -petscspace_poly_tensor 1 -dm_landau_type
.1 -dm_refine 1 -dm_landau_gpu_assembly false *-dm_view hdf5:f.h5 -vec_view
TEST*/
On Wed, Jun 23, 2021 at 1:38 PM Mark Adams <mfadams at lbl.gov> wrote:
> Landau ex1 should work. I will test.
> On Wed, Jun 23, 2021 at 10:47 AM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Jun 23, 2021 at 10:44 AM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Use VecGetArrayRead/Write() to get up-to-date host pointers to the
>>> vector array.
>> I think Mark is saying that those are not working. We do call
>> VecGetArrayRead() in the HDF5 code.
>> Mark, it seem like a small broken code is necessary.
>> Thanks,
>> Matt
>>> --Junchao Zhang
>>> On Wed, Jun 23, 2021 at 9:15 AM Mark Adams <mfadams at lbl.gov> wrote:
>>>> First, there seem to be two pages for VecGetArrayAndMemType (one has a
>>>> pointer to the other).
>>>> So I need to get a CPU array for HDF5 viewing. Totally broken for
>>>> devices.
>>>> I don't find a VecGetArrayCpu[HOST] that does the right thing.
>>>> Perhaps have VecGetArrayAndMemType return a valid CPU pointer when
>>>> "mtype==NULL"?
>>>> Mark
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210623/ea583653/attachment-0001.html>
Name: Screen Shot 2021-06-23 at 3.30.53 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210623/ea583653/attachment-0002.png>
Name: Screen Shot 2021-06-23 at 3.46.04 PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210623/ea583653/attachment-0003.png>
