[petsc-dev] kokkos test fail in branch
Mark Adams mfadams at lbl.gov
Sat Jun 5 10:24:54 CDT 2021
This is posted in Barry's MR, but I get this error with Kokkos-cuda on
Summit. Failing to open a shared lib.
Thoughts?
11:15 barry/2020-11-11/cleanup-matsetvaluesdevice=
/gpfs/alpine/csc314/scratch/adams/petsc$ make
PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 check
Running check examples to verify correct installation
Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and
C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
C/C++ example src/snes/tutorials/ex19 run successfully with cuda
gmake[3]: [runex3k_kokkos] Error 127 (ignored)
1,25c1,2
< atol=1e-50, rtol=1e-08, stol=1e-08, maxit=50, maxf=10000
< Vec Object: Exact Solution 2 MPI processes
<   type: mpikokkos
< Process [0]
< 0.
< 0.015625
< 0.125
< Process [1]
< 0.421875
< 1.
< Vec Object: Forcing function 2 MPI processes
<   type: mpikokkos
< Process [0]
< 1e-72
< 1.50024
< 3.01563
< Process [1]
< 4.67798
< 7.
<   0 SNES Function norm 5.414682427127e+00
<   1 SNES Function norm 2.952582418265e-01
<   2 SNES Function norm 4.502293658739e-04
<   3 SNES Function norm 1.389665806646e-09
< Number of SNES iterations = 3
< Norm of error 1.49752e-10 Iterations 3
*> ./ex3k: error while loading shared libraries: libpetsc.so.3.015: cannot
open shared object file: No such file or directory> ./ex3k: error while
loading shared libraries: libpetsc.so.3.015: cannot open shared object
file: No such file or directory*
/gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210605/56f82939/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210605/56f82939/attachment-0001.obj>
