[petsc-dev] kokkos test fail in branch
    Junchao Zhang
    junchao.zhang at gmail.com
    Sat Jun  5 11:16:18 CDT 2021
$rm ex3k
$make ex3k
and run again?
--Junchao Zhang
On Sat, Jun 5, 2021 at 10:25 AM Mark Adams <mfadams at lbl.gov> wrote:
> This is posted in Barry's MR, but I get this error with Kokkos-cuda on
> Summit. Failing to open a shared lib.
> Thoughts?
> Mark
> 11:15 barry/2020-11-11/cleanup-matsetvaluesdevice=
> /gpfs/alpine/csc314/scratch/adams/petsc$ make
> PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
> PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 check
> Running check examples to verify correct installation
> Using PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc and
> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
> C/C++ example src/snes/tutorials/ex19 run successfully with 2 MPI processes
> C/C++ example src/snes/tutorials/ex19 run successfully with cuda
> gmake[3]: [runex3k_kokkos] Error 127 (ignored)
> 1,25c1,2
> < atol=1e-50, rtol=1e-08, stol=1e-08, maxit=50, maxf=10000
> < Vec Object: Exact Solution 2 MPI processes
> <   type: mpikokkos
> < Process [0]
> < 0.
> < 0.015625
> < 0.125
> < Process [1]
> < 0.421875
> < 1.
> < Vec Object: Forcing function 2 MPI processes
> <   type: mpikokkos
> < Process [0]
> < 1e-72
> < 1.50024
> < 3.01563
> < Process [1]
> < 4.67798
> < 7.
> <   0 SNES Function norm 5.414682427127e+00
> <   1 SNES Function norm 2.952582418265e-01
> <   2 SNES Function norm 4.502293658739e-04
> <   3 SNES Function norm 1.389665806646e-09
> < Number of SNES iterations = 3
> < Norm of error 1.49752e-10 Iterations 3
> *> ./ex3k: error while loading shared libraries: libpetsc.so.3.015: cannot
> open shared object file: No such file or directory> ./ex3k: error while
> loading shared libraries: libpetsc.so.3.015: cannot open shared object
> file: No such file or directory*
> /gpfs/alpine/csc314/scratch/adams/petsc/src/snes/tutorials
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210605/5a9bdbd5/attachment.html>
