[petsc-dev] [petsc-users] ex5k.kokkos compile error
    Mark Adams
    mfadams at lbl.gov
    Thu Jun  3 16:11:50 CDT 2021
I was doing 'make ex5k.kokkos'
It would be nice if that failed, but it building now.
On Thu, Jun 3, 2021 at 10:57 AM Junchao Zhang <junchao.zhang at gmail.com>
wrote:
> (Moved to petsc-dev)
> Mark,
>    Is it because your branch is out of date?  petsc should use nvcc_wapper
> to compile ex5k.kokkos.cxx.  See mine
> $cd ~/petsc/src/mat/tutorials
> $ make ex5k
> PATH=/home/jczhang/spack/opt/spack/linux-ubuntu18.04-skylake_avx512/gcc-8.3.0/gdb-9.1-bzjzolog57gom5anscfcb3oe6uqr6s6m/bin:/home/jczhang/spack/opt/spack/linux-ubuntu18.04-skylake_avx512/gcc-8.3.0/bear-2.2.0-xhfk3moyh7jled6o62f3om557iia6oun/bin:/home/jczhang/spack/opt/spack/linux-ubuntu18.04-skylake_avx512/gcc-8.3.0/perl-5.30.3-2boymujkmxezayez4emfw5sw5wuqgar6/bin:/home/jczhang/spack/opt/spack/linux-ubuntu18.04-skylake_avx512/gcc-8.3.0/openmpi-4.0.2-7vmyqiyk4iyvdeoqpux7fyoce6mjt7iw/bin:/home/jczhang/spack/opt/spack/linux-ubuntu18.04-skylake_avx512/gcc-8.3.0/cuda-10.2.89-uy4hlcnd7svrcahaguwx4bzl7ujoqx2v/bin:/nfs/gce/software/spack/opt/spack/linux-ubuntu18.04-x86_64/gcc-7.3.0/cmake-3.20.0-vov726r/bin:/nfs/gce/software/spack/opt/spack/linux-ubuntu18.04-x86_64/gcc-7.3.0/gcc-8.3.0-fjpc5ys/bin:/home/jczhang/soft/bin:/home/jczhang/spack/bin:/home/jczhang/arm/forge/20.2/bin:/home/jczhang/.vscode-server/data/User/globalStorage/llvm-vs-code-extensions.vscode-clangd/install/10.0.0/clangd_10.0.0/bin:/home/jczhang/.vscode-server/bin/054a9295330880ed74ceaedda236253b4f39a335/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin:`dirname
> nvcc` NVCC_WRAPPER_DEFAULT_COMPILER=gcc
> /home/jczhang/petsc/linux-kokkos-dbg/bin/nvcc_wrapper --expt-extended-lambda
> -Xcompiler -fPIC -g  -gencode arch=compute_70,code=sm_70
>  -I/home/jczhang/spack/opt/spack/linux-ubuntu18.04-skylake_avx512/gcc-8.3.0/openmpi-4.0.2-7vmyqiyk4iyvdeoqpux7fyoce6mjt7iw/include
> -Wno-deprecated-gpu-targets  -I/home/jczhang/petsc/include
> -I/home/jczhang/petsc/linux-kokkos-dbg/include
>   -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas
> -fstack-protector -fvisibility=hidden -g -O0   ex5k.kokkos.cxx
>  -Wl,-rpath,/home/jczhang/petsc/linux-kokkos-dbg/lib
> -L/home/jczhang/petsc/linux-kokkos-dbg/lib
> -L/home/jczhang/petsc/linux-kokkos-dbg/lib -lpetsc -lkokkoskernels
> -lkokkoscontainers -lkokkoscore -llapack -lblas -lm -lcudart -lcufft
> -lcublas -lcusparse -lcusolver -lcurand -lX11 -lquadmath -lstdc++ -ldl -o
> ex5k
> --Junchao Zhang
> On Thu, Jun 3, 2021 at 8:32 AM Mark Adams <mfadams at lbl.gov> wrote:
>> I am getting this error:
>> 09:22 adams/landau-mass-opt=
>> /gpfs/alpine/csc314/scratch/adams/petsc/src/mat/tutorials$ make
>> PETSC_DIR=/gpfs/alpine/csc314/scratch/adams/petsc
>> PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10 ex5k.kokkos
>> mpicxx -fPIC -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10
>> -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4 -O0   -fPIC -g -DLANDAU_DIM=2
>> -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4 -O0
>> -fPIC    -I/gpfs/alpine/csc314/scratch/adams/petsc/include
>> -I/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include
>> -I/sw/summit/cuda/10.1.243/include     ex5k.kokkos.cxx
>>  -Wl,-rpath,/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib
>> -L/gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/lib
>> -L/autofs/nccs-svm1_sw/summit/.swci/1-compute/opt/spack/20180914/linux-rhel7-ppc64le/gcc-6.4.0/netlib-lapack-3.8.0-wcabdyqhdi5rooxbkqa6x5d7hxyxwdkm/lib64
>> -Wl,-rpath,/sw/summit/cuda/10.1.243/lib64 -L/sw/summit/cuda/10.1.243/lib64
>> -lpetsc -lkokkoskernels -lkokkoscontainers -lkokkoscore -lp4est -lsc -lblas
>> -llapack -ltriangle -lm -lz -lcudart -lcufft -lcublas -lcusparse -lcusolver
>> -lcurand -lstdc++ -ldl -o ex5k.kokkos
>> In file included from
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include/KokkosCore_Config_SetupBackend.hpp:47:0,
>>                  from
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include/Kokkos_Macros.hpp:109,
>>                  from
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include/Kokkos_Core_fwd.hpp:52,
>>                  from
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include/Kokkos_Core.hpp:51,
>>                  from ex5k.kokkos.cxx:10:
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include/setup/Kokkos_Setup_Cuda.hpp:54:2:
>> error: #error "KOKKOS_ENABLE_CUDA defined but the compiler is not defining
>> the __CUDACC__ macro as expected"
>>  #error \
>> /sw/summit/cuda/10.1.243/include/crt/common_functions.h:267:0,
>>                  from /sw/summit/cuda/10.1.243/include/cuda_runtime.h:115,
>>                  from
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include/setup/Kokkos_Setup_Cuda.hpp:68,
>>                  from
>> /gpfs/alpine/csc314/scratch/adams/petsc/arch-summit-opt-gnu-kokkos-notpl-cuda10/include/KokkosCore_Config_SetupBackend.hpp:47,
>>                  from
>>                  from
>>                  from
>> /sw/summit/cuda/10.1.243/include/crt/math_functions.h:8944:72: error:
>> 'int std::isnan(double)' conflicts with a previous declaration
>>  __DEVICE_FUNCTIONS_DECL__ __cudart_builtin__ int isnan(double x) throw();
>> Here is my config file:
>> #!/usr/bin/env python
>> #  -lnvToolsExt
>> if __name__ == '__main__':
>>   import sys
>>   import os
>>   sys.path.insert(0, os.path.abspath('config'))
>>   import configure
>>   configure_options = [
>>     '--with-fc=0',
>>     '--CFLAGS=-fPIC -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10
>> -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4',
>>     '--CXXFLAGS=-fPIC -g -DLANDAU_DIM=2 -DLANDAU_MAX_SPECIES=10
>>     '--COPTFLAGS=-O0',
>>     '--CXXOPTFLAGS=-O0',
>>     '--CUDAOPTFLAGS=-O0',
>> #    'LIBS= -L'+os.environ['CUDAPATH']+'/lib64 -lnvToolsExt',
>>     '--CUDAFLAGS=-Xcompiler -rdynamic -lineinfo -DLANDAU_DIM=2
>> -DLANDAU_MAX_SPECIES=10 -DPETSC_HAVE_CUDA_ATOMIC -DLANDAU_MAX_Q=4',
>>     '--with-ssl=0',
>>     '--with-batch=0',
>>     '--with-cxx=mpicxx',
>>     '--with-mpiexec=jsrun -g1 ',
>>     '--with-openmp=0',
>> #    '--with-threadsafety=1',
>> #    '--with-log=0',
>>     '--with-cuda=1',
>>     '--with-cuda-gencodearch=70',
>>     '--with-cudac=nvcc',
>>     '--download-p4est=1',
>>     '--download-zlib',
>> #    '--download-hdf5=1',
>> #    '--download-metis',
>> #    '--download-superlu_dist',
>> #    '--download-superlu_dist-commit=HEAD',
>> #    '--download-hypre-configure-arguments=HYPRE_CUDA_SM=70',
>>     #'--with-hwloc=0',
>> #    '--download-parmetis',
>>     #'--download-hypre',
>>     '--download-triangle',
>>     #'--download-amgx',
>>     #'--download-fblaslapack',
>>     '--with-blaslapack-lib=-L' + os.environ['OLCF_NETLIB_LAPACK_ROOT'] +
>> '/lib64 -lblas -llapack',
>>     #'--download-openblas',
>>     '--with-cc=mpicc',
>>     #'--with-fc=mpif90',
>>     '--with-shared-libraries=1',
>>     #  '--known-mpi-shared-libraries=1',
>>     '--with-x=0',
>>     '--with-64-bit-indices=0',
>>     '--with-debugging=1',
>>     '--download-kokkos',
>>     '--with-ctable=0',
>>     '--with-make-np=8',
>>     '--download-kokkos-kernels',
>> #    '--with-kokkos-cuda-arch=VOLTA70',
>>     '--with-kokkos-kernels-tpl=0',
>> '--download-kokkos-cmake-arguments=-DKokkos_ENABLE_AGGRESSIVE_VECTORIZATION=ON
>> -DKokkos_ARCH_POWER9=ON',
>> #    '--download-kokkos-commit=origin/develop',
>> #    '--download-kokkos-kernels-commit=origin/develop',
>>     'PETSC_ARCH=arch-summit-opt-gnu-kokkos-notpl-cuda10',
>>   configure.petsc_configure(configure_options)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210603/1c2aa698/attachment.html>
