[petsc-dev] "Search" does not work in the testing system?
Satish Balay
balay at mcs.anl.gov
Fri Jan 29 11:54:21 CST 2021
gmakegentest.py need to be rerun.
I just do:
make cleantest
make test search=...
Satish
On Fri, 29 Jan 2021, Fande Kong wrote:
> Thanks so much!
> It worked well with existing examples. If I add a new example, this does
> not work anymore. What extra step I need to take?
> Fande
> On Wed, Jan 27, 2021 at 4:50 PM Scott Kruger <kruger at txcorp.com> wrote:
> > You can change the 'test' target to 'print-test' to see the actual targets
> > you'll be testing.
> > You can also just change your search string to src/snes/tutorials/ex1.c to
> > grab all tests associated with ex1.c.
> > Scott
> > On 1/27/21 4:45 PM, Zhang, Hong via petsc-dev wrote:
> > make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1_*'
> > or
> > make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test globsearch='snes_tutorials-ex1_*’
> > Hong (Mr.)
> > On Jan 27, 2021, at 5:21 PM, Fande Kong <fdkong.jd at gmail.com> <fdkong.jd at gmail.com> wrote:
> > Hi All,
> > I want to run one particular SNES test using the following command-line:
> > "make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1'"
> > I got the following output:
> > "Using MAKEFLAGS: search=snes_tutorials-ex1% PETSC_ARCH=arch-darwin-c-debug PETSC_DIR=/Users/kongf/projects/moose4/petsc"
> > But I did not see any useful test information.
> > Could you kindly let me know what I did wrong?
> > Thanks,
> > Fande
> > Tech-X Corporation kruger at txcorp.com
> > 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
> > Boulder, CO 80303 Fax: (303) 448-7756
