[petsc-dev] "Search" does not work in the testing system?
    Fande Kong
    fdkong.jd at gmail.com
    Fri Jan 29 11:46:56 CST 2021
Thanks so much!
It worked well with existing examples. If I add a new example, this does
not work anymore. What extra step I need to take?
Fande
On Wed, Jan 27, 2021 at 4:50 PM Scott Kruger <kruger at txcorp.com> wrote:
> You can change the 'test' target to 'print-test' to see the actual targets
> you'll be testing.
> You can also just change your search string to src/snes/tutorials/ex1.c to
> grab all tests associated with ex1.c.
> Scott
> On 1/27/21 4:45 PM, Zhang, Hong via petsc-dev wrote:
> make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1_*'
> or
> make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test globsearch='snes_tutorials-ex1_*’
> Hong (Mr.)
> On Jan 27, 2021, at 5:21 PM, Fande Kong <fdkong.jd at gmail.com> <fdkong.jd at gmail.com> wrote:
> Hi All,
> I want to run one particular SNES test using the following command-line:
> "make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1'"
> I got the following output:
> "Using MAKEFLAGS: search=snes_tutorials-ex1% PETSC_ARCH=arch-darwin-c-debug PETSC_DIR=/Users/kongf/projects/moose4/petsc"
> But I did not see any useful test information.
> Could you kindly let me know what I did wrong?
> Thanks,
> Fande
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
> Boulder, CO 80303                Fax:   (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210129/8dbabdba/attachment.html>
