[petsc-dev] "Search" does not work in the testing system?
Scott Kruger
kruger at txcorp.com
Fri Jan 29 11:58:58 CST 2021
`config/gmakegentest.py` if your PETSC_DIR/PETSC_ARCH environment
variables are set, otherwise
use the --petsc-dir and --petsc-arch arguments.
This is likely TMI, but this script generates the
$PETSC_ARCH/tests/testfiles files that is used by
gmakefile to understand the dependencies. When you have a new file, you
need to let the make
system know about that new dependency.
Scott
On 1/29/21 10:46 AM, Fande Kong wrote:
> Thanks so much!
> It worked well with existing examples. If I add a new example, this
> does not work anymore. What extra step I need to take?
> Fande
> On Wed, Jan 27, 2021 at 4:50 PM Scott Kruger <kruger at txcorp.com
> <mailto:kruger at txcorp.com>> wrote:
> You can change the 'test' target to 'print-test' to see the actual
> targets you'll be testing.
> You can also just change your search string to
> src/snes/tutorials/ex1.c to grab all tests associated with ex1.c.
> Scott
> On 1/27/21 4:45 PM, Zhang, Hong via petsc-dev wrote:
>> make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1_*'
>> or
>> make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test globsearch='snes_tutorials-ex1_*’
>> Hong (Mr.)
>>> On Jan 27, 2021, at 5:21 PM, Fande Kong<fdkong.jd at gmail.com> <mailto:fdkong.jd at gmail.com> wrote:
>>> Hi All,
>>> I want to run one particular SNES test using the following command-line:
>>> "make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1'"
>>> I got the following output:
>>> "Using MAKEFLAGS: search=snes_tutorials-ex1% PETSC_ARCH=arch-darwin-c-debug PETSC_DIR=/Users/kongf/projects/moose4/petsc"
>>> But I did not see any useful test information.
>>> Could you kindly let me know what I did wrong?
>>> Thanks,
>>> Fande
> Tech-X Corporationkruger at txcorp.com <mailto:kruger at txcorp.com>
> 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
> Boulder, CO 80303 Fax: (303) 448-7756
Tech-X Corporation kruger at txcorp.com
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210129/5094f6f3/attachment.html>
