[petsc-dev] "Search" does not work in the testing system?
Scott Kruger kruger at txcorp.com
Wed Jan 27 17:50:18 CST 2021
You can change the 'test' target to 'print-test' to see the actual
targets you'll be testing.
You can also just change your search string to src/snes/tutorials/ex1.c
to grab all tests associated with ex1.c.
Scott
On 1/27/21 4:45 PM, Zhang, Hong via petsc-dev wrote:
> make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1_*'
> or
> make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test globsearch='snes_tutorials-ex1_*’
> Hong (Mr.)
>> On Jan 27, 2021, at 5:21 PM, Fande Kong <fdkong.jd at gmail.com> wrote:
>> Hi All,
>> I want to run one particular SNES test using the following command-line:
>> "make PETSC_DIR=/Users/kongf/projects/moose4/petsc PETSC_ARCH=arch-darwin-c-debug -f gmakefile test search='snes_tutorials-ex1'"
>> I got the following output:
>> "Using MAKEFLAGS: search=snes_tutorials-ex1% PETSC_ARCH=arch-darwin-c-debug PETSC_DIR=/Users/kongf/projects/moose4/petsc"
>> But I did not see any useful test information.
>> Could you kindly let me know what I did wrong?
>> Thanks,
>> Fande
Tech-X Corporation               kruger at txcorp.com
5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
Boulder, CO 80303                Fax:   (303) 448-7756
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210127/e64606d1/attachment.html>
