[petsc-dev] bin/sh error while running tests
Pierre Jolivet pierre at joliv.et
Wed Jan 20 07:03:20 CST 2021
Sorry for the noise, I'm now just realizing that it is in fact exactly the same bash-ism… (I prefer my “fix” though, but I guess the rest of Stefano’s comment still holds true).
Pierre
> On 20 Jan 2021, at 1:59 PM, Pierre Jolivet <pierre at joliv.et> wrote:
>> On 20 Jan 2021, at 12:11 PM, Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
>> This is an issue with the default shell used by the makefile. Below is my fix. We should probably have a CI machine that checks for these shell-related errors.
> I second this. Just spent too much time finding this other bash-ism in gmakefile.test… https://gitlab.com/petsc/petsc/-/commit/e4b11943e93779206a0e5f2091646de2e86b10e3#551c4017403b9179c385d5600f43348b6288a751 <https://gitlab.com/petsc/petsc/-/commit/e4b11943e93779206a0e5f2091646de2e86b10e3#551c4017403b9179c385d5600f43348b6288a751>
> 2021-01-20T11:21:22.5942304Z /usr/bin/sh: 1: test: false: unexpected operator
> 2021-01-20T11:21:22.5981176Z make: *** [gmakefile.test:270: check-test-errors] Error 1
> Thanks,
> Pierre
>> diff --git a/gmakefile.test b/gmakefile.test
>> index c38e37f..ffd7bdb 100644
>> --- a/gmakefile.test
>> +++ b/gmakefile.test
>> @@ -379,10 +379,11 @@ starttime: pre-clean $(libpetscall)
>>         @$(eval STARTTIME := $(shell date +%s))
>>  report_tests: starttime $(TESTTARGETS)
>> +ifeq ($(showreport),true)
>>         @$(eval ENDTIME := $(shell date +%s))
>> -       - at if test ${showreport} == "true"; then  elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
>> -       $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d $(TESTDIR)/counts -t 5 -e $${elapsed_time};\
>> -    fi
>> +       elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
>> +       $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d $(TESTDIR)/counts -t 5 -e $${elapsed_time};
>> +endif
>> Il giorno mar 19 gen 2021 alle ore 20:41 Scott Kruger <kruger at txcorp.com <mailto:kruger at txcorp.com>> ha scritto:
>> I can't reproduce this with the latest master:
>> hip 1261: git pull
>> Already up to date.
>> hip 1262: make -f gmakefile.test test search='notatest'
>> Using MAKEFLAGS: -- search=notatest
>> hip 1263:
>> On 1/19/21 8:19 AM, Stefano Zampini wrote:
>>> Just rebased over latest master and got this
>>> zampins at vulture:~/Devel/petsc$ make -f gmakefile.test test search='notatest'
>>> Stefano
>> Tech-X Corporation               kruger at txcorp.com <mailto:kruger at txcorp.com>
>> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
>> Boulder, CO 80303                Fax:   (303) 448-7756
>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210120/7b0e8919/attachment-0001.html>
