[petsc-dev] bin/sh error while running tests
Pierre Jolivet
pierre at joliv.et
Wed Jan 20 06:59:54 CST 2021
> On 20 Jan 2021, at 12:11 PM, Stefano Zampini <stefano.zampini at gmail.com> wrote:
> This is an issue with the default shell used by the makefile. Below is my fix. We should probably have a CI machine that checks for these shell-related errors.
I second this. Just spent too much time finding this other bash-ism in gmakefile.test… https://gitlab.com/petsc/petsc/-/commit/e4b11943e93779206a0e5f2091646de2e86b10e3#551c4017403b9179c385d5600f43348b6288a751 <https://gitlab.com/petsc/petsc/-/commit/e4b11943e93779206a0e5f2091646de2e86b10e3#551c4017403b9179c385d5600f43348b6288a751>
2021-01-20T11:21:22.5942304Z /usr/bin/sh: 1: test: false: unexpected operator
2021-01-20T11:21:22.5981176Z make: *** [gmakefile.test:270: check-test-errors] Error 1
Pierre
> diff --git a/gmakefile.test b/gmakefile.test
> index c38e37f..ffd7bdb 100644
> --- a/gmakefile.test
> +++ b/gmakefile.test
> @@ -379,10 +379,11 @@ starttime: pre-clean $(libpetscall)
> @$(eval STARTTIME := $(shell date +%s))
> report_tests: starttime $(TESTTARGETS)
> +ifeq ($(showreport),true)
> @$(eval ENDTIME := $(shell date +%s))
> - - at if test ${showreport} == "true"; then elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
> - $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d $(TESTDIR)/counts -t 5 -e $${elapsed_time};\
> - fi
> + elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
> + $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d $(TESTDIR)/counts -t 5 -e $${elapsed_time};
> +endif
> Il giorno mar 19 gen 2021 alle ore 20:41 Scott Kruger <kruger at txcorp.com <mailto:kruger at txcorp.com>> ha scritto:
> I can't reproduce this with the latest master:
> hip 1261: git pull
> Already up to date.
> hip 1262: make -f gmakefile.test test search='notatest'
> Using MAKEFLAGS: -- search=notatest
> hip 1263:
> On 1/19/21 8:19 AM, Stefano Zampini wrote:
>> Just rebased over latest master and got this
>> zampins at vulture:~/Devel/petsc$ make -f gmakefile.test test search='notatest'
>> Stefano
> Tech-X Corporation kruger at txcorp.com <mailto:kruger at txcorp.com>
> 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196
> Boulder, CO 80303 Fax: (303) 448-7756
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210120/1b7e39e3/attachment.html>
