[petsc-dev] bin/sh error while running tests
    Stefano Zampini
    stefano.zampini at gmail.com
    Wed Jan 20 05:50:56 CST 2021
This has been introduced in f42deef95efdb32c74e20b044efbd18de6bff042.
That commit also broke another feature that I find very useful, which is to
rerun only the failed tests.
Now, the echofailures.sh file is no longer updated unless we do full
testing.
Can we please revert that commit?
Il giorno mer 20 gen 2021 alle ore 14:11 Stefano Zampini <
stefano.zampini at gmail.com> ha scritto:
> This is an issue with the default shell used by the makefile. Below is my
> fix. We should probably have a CI machine that checks for these
> shell-related errors.
> diff --git a/gmakefile.test b/gmakefile.test
> index c38e37f..ffd7bdb 100644
> --- a/gmakefile.test
> +++ b/gmakefile.test
> @@ -379,10 +379,11 @@ starttime: pre-clean $(libpetscall)
>         @$(eval STARTTIME := $(shell date +%s))
>  report_tests: starttime $(TESTTARGETS)
> +ifeq ($(showreport),true)
>         @$(eval ENDTIME := $(shell date +%s))
> -       - at if test ${showreport} == "true"; then
>  elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
> -       $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d
> $(TESTDIR)/counts -t 5 -e $${elapsed_time};\
> -    fi
> +       elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
> +       $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d
> +endif
> Il giorno mar 19 gen 2021 alle ore 20:41 Scott Kruger <kruger at txcorp.com>
> ha scritto:
>> I can't reproduce this with the latest master:
>> hip 1261: git pull
>> Already up to date.
>> hip 1262: make -f gmakefile.test test search='notatest'
>> Using MAKEFLAGS: -- search=notatest
>> hip 1263:
>> On 1/19/21 8:19 AM, Stefano Zampini wrote:
>> Just rebased over latest master and got this
>> zampins at vulture:~/Devel/petsc$ make -f gmakefile.test test
>> search='notatest'
>> /bin/sh: 1: test: false: unexpected operator
>> Stefano
>> Tech-X Corporation               kruger at txcorp.com
>> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
>> Boulder, CO 80303                Fax:   (303) 448-7756
> Stefano
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210120/40aad03a/attachment.html>
