[petsc-dev] bin/sh error while running tests
Stefano Zampini stefano.zampini at gmail.com
Wed Jan 20 05:11:09 CST 2021
This is an issue with the default shell used by the makefile. Below is my
fix. We should probably have a CI machine that checks for these
shell-related errors.
diff --git a/gmakefile.test b/gmakefile.test
index c38e37f..ffd7bdb 100644
--- a/gmakefile.test
+++ b/gmakefile.test
@@ -379,10 +379,11 @@ starttime: pre-clean $(libpetscall)
        @$(eval STARTTIME := $(shell date +%s))
 report_tests: starttime $(TESTTARGETS)
+ifeq ($(showreport),true)
        @$(eval ENDTIME := $(shell date +%s))
-       - at if test ${showreport} == "true"; then
 elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
-       $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d
$(TESTDIR)/counts -t 5 -e $${elapsed_time};\
-    fi
+       elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \
+       $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d
+endif
Il giorno mar 19 gen 2021 alle ore 20:41 Scott Kruger <kruger at txcorp.com>
ha scritto:
> I can't reproduce this with the latest master:
> hip 1261: git pull
> Already up to date.
> hip 1262: make -f gmakefile.test test search='notatest'
> Using MAKEFLAGS: -- search=notatest
> hip 1263:
> On 1/19/21 8:19 AM, Stefano Zampini wrote:
> Just rebased over latest master and got this
> zampins at vulture:~/Devel/petsc$ make -f gmakefile.test test
> search='notatest'
> /bin/sh: 1: test: false: unexpected operator
> Stefano
> Tech-X Corporation               kruger at txcorp.com
> 5621 Arapahoe Ave, Suite A       Phone: (720) 466-3196
> Boulder, CO 80303                Fax:   (303) 448-7756
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210120/7f3ff753/attachment.html>
