[petsc-dev] Rebuilding pets-library only
Blaise A Bourdin bourdin at lsu.edu
Wed Feb 17 10:17:48 CST 2021
Thanks
Blaise
On Feb 17, 2021, at 10:03 AM, Jed Brown <jed at jedbrown.org<mailto:jed at jedbrown.org>> wrote:
make libs should do that.
Blaise A Bourdin <bourdin at lsu.edu<mailto:bourdin at lsu.edu>> writes:
Is there a way to rebuild the petsc library only, skipping rebuilding mpi4py and petsc4py if petsc is configured with them? I know I can ctrl-C this step if all I want is to rebuild the lib, but I would not mind a more elegant way..
Blaise
A.K. & Shirley Barton Professor of  Mathematics
Adjunct Professor of Mechanical Engineering
Adjunct of the Center for Computation & Technology
Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA
Tel. +1 (225) 578 1612, Fax  +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20210217/806c194a/attachment.html>
