[petsc-dev] Rebuilding pets-library only
Jed Brown
jed at jedbrown.org
Wed Feb 17 10:03:44 CST 2021
make libs should do that.
Blaise A Bourdin <bourdin at lsu.edu> writes:
> Hi,
> Is there a way to rebuild the petsc library only, skipping rebuilding mpi4py and petsc4py if petsc is configured with them? I know I can ctrl-C this step if all I want is to rebuild the lib, but I would not mind a more elegant way..
> Regards,
> Blaise
> A.K. & Shirley Barton Professor of Mathematics
> Adjunct Professor of Mechanical Engineering
> Adjunct of the Center for Computation & Technology
> Louisiana State University, Lockett Hall Room 344, Baton Rouge, LA 70803, USA
> Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 Web http://www.math.lsu.edu/~bourdin
